WD 4TB Red NAS Desktop  Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD40EFRX
Quicklinx: 8YPMWS00 Mfr#: WD40EFRX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
21 in stock
£100.12 ex VAT
£120.14 inc VAT
WD Red™: The colour of NAS.
WD Red is designed for NAS systems that have 1-8 drive bays. Available in capacities ranging from 1TB to 8TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
• Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-8 bay systems
• Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
• Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
  • For personal or home office
    Stream, backup, share, and organize your digital content at home with a NAS and WD Red drives designed to effortlessly share content with the devices in your personal or home office environments. NASware 3.0 technology increases your drives' compatibility with your existing network and devices, TV, stereo, and more. Live in a connected world.
  • Exclusive NASware 3.0
    Built into every WD Red hard drive, NASware 3.0's advanced technology improves your system's storage performance by increasing compatibility, integration, upgradeability, and reliability.
  • Built for optimal NAS compatibility
    Designed for personal and home office NAS systems, a unique algorithm balances performance and reliability in NAS and RAID environments. WD Red drives are optimized for environments where idle time is available to perform necessary background operations. To ensure optimal performance, always check compatibility with your system.
  • 24/7 environment
    Since your NAS system is always on, a reliable drive is essential. The WD Red drive is engineered to tackle 24x7 environments.
WD Red Plus NAS Hard Drive WD40EFRX - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal - Native Command Queuing (NCQ), IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Native Command Queuing (NCQ), IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
680 g
3-year warranty
My Cloud EX2; EX4
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
680 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
4.5 Watt (read) , 4.5 Watt (write) , 3.3 Watt (idle) , 0.4 Watt (sleep)
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
25 dBA
WD My Cloud EX2 , WD My Cloud EX4
8YPM StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.30
8YPM StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
8YPM StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £65.05
Type: Hard drive
Capacity: 4TB
Brand: WD
Price Range Ex VAT: 100 - 150
