Every journey needs a passport. The My Passport drive is trusted, portable storage that gives you the confidence and freedom to drive forward in life. With a stylish design that fits in the palm of your hand, there's space to store, organize, and share your photos, videos, music, and documents. Perfectly paired with WD Backup software and password protection, the My Passport drive helps keep your digital life's contents safe.
Slim style
The My Passport drive has been redesigned for you to make the most of your own journey. It features a convenient, slim form factor. -
Locked down
The My Passport drive's built-in 256-bit AES hardware encryption with password protection helps keep your digital life's contents secure. Just activate password protection and set your own personalised password using WD Discovery. -
Super easy
The My Passport portable storage is ready right out of the box including all necessary cables. And with SuperSpeed USB, you can quickly start backing up everything in your life and keep driving forward.
- WD My Passport WDBPKJ0040BRD - hard drive - 4 TB - USB 3.2 Gen 1
- Hard drive - external (portable)
- Capacity
- 4 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.2 Gen 1
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Password authentication, automatic backup
- Power Source
- USB bus
- Enclosure Colour
- Red
- 75 mm x 107.2 mm x 19.15 mm
- 210 g
- Localisation
- Worldwide (excluding China)
- 3-year warranty
- Capacity
- 4 TB
- 256-bit AES
- Interface
- USB 3.2 Gen 1
- 75 mm
- 107.2 mm
- 19.15 mm
- 210 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.2 Gen 1
- Power Source
- USB bus
- Software Included
- WD Security, WD Drive Utilities, WD Backup, WD Discovery
- OS Required
- Windows 10 or later
- Cables Included
- 1 x USB 3.0 cable - external
- RoHS, Directive 2002/95/EC
- Enclosure Colour
- Red
- Localisation
- Package Type
- Retail
- Shipping Width
- 10.35 cm
- Shipping Depth
- 3.98 cm
- Shipping Height
- 14.6 cm
- Shipping Weight
- 340 g
- Limited warranty - 3 years
- 5 °C
- 35 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 65 °C
- 20 - 80%
