WD 4TB My Passport 2.5" USB 3.0 Portable Hard Drive - Red
Quicklinx: FK61WS00 Mfr#: WDBPKJ0040BRD-WESN
Form Factor: 2.5
Type: Hard drive
Interface Type: USB
Capacity: 4TB
Spin Speed (rpm): [N/A]
£98.21 ex VAT
£117.85 inc VAT
Every journey needs a passport. The My Passport drive is trusted, portable storage that gives you the confidence and freedom to drive forward in life. With a stylish design that fits in the palm of your hand, there's space to store, organize, and share your photos, videos, music, and documents. Perfectly paired with WD Backup software and password protection, the My Passport drive helps keep your digital life's contents safe.
  • Slim style
    The My Passport drive has been redesigned for you to make the most of your own journey. It features a convenient, slim form factor.
  • Locked down
    The My Passport drive's built-in 256-bit AES hardware encryption with password protection helps keep your digital life's contents secure. Just activate password protection and set your own personalised password using WD Discovery.
  • Super easy
    The My Passport portable storage is ready right out of the box including all necessary cables. And with SuperSpeed USB, you can quickly start backing up everything in your life and keep driving forward.
WD My Passport WDBPKJ0040BRD - hard drive - 4 TB - USB 3.2 Gen 1
Hard drive - external (portable)
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 1
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, automatic backup
Power Source
USB bus
Enclosure Colour
Red
75 mm x 107.2 mm x 19.15 mm
210 g
Worldwide (excluding China)
3-year warranty
4 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 1
75 mm
107.2 mm
19.15 mm
210 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.2 Gen 1
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Backup, WD Discovery
Windows 10 or later
1 x USB 3.0 cable - external
RoHS, Directive 2002/95/EC
Enclosure Colour
Red
Package Type
Retail
Shipping Width
10.35 cm
Shipping Depth
3.98 cm
Shipping Height
14.6 cm
Shipping Weight
340 g
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
20 - 80%
Form Factor: 2.5
Type: Hard drive
Interface Type: USB
Capacity: 4TB
Brand: WD
