WD 4TB Gold Enterprise Class 3.5" SATA 6Gb/s 7200RPM 256MB
Quicklinx: FJ4TWS00 Mfr#: WD4003FRYZ
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£122.54 ex VAT
£147.04 inc VAT
Conquer tough workloads with enterprise-class WD Gold HDDs. This highly reliable solution for demanding storage environments provides up to 2.5M hours MTBF, vibration protection technology and a low power draw thanks to HelioSeal technology. Specifically designed for use in enterprise-class data centers and storage systems, the WD Gold SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
  • Beyond expectations
    WD Gold hard drives are performance-optimized for heavy application workloads. The WD Gold HDD's wide capacity range solves for the most demanding storage environments.
  • Enhanced reliability
    With up to 2.5M hours MTBF, WD Gold hard drives deliver enhanced levels of dependability and durability.
  • A world-class performer
    Delivering excellent service to any storage environment, WD Gold hard drives are designed to handle workloads up to 550TB per year - among the highest of any 3.5-inch hard drive.
  • Vibration protection
    WD Gold has sophisticated monitoring electronics that help correct linear and rotational vibrations in real time using enhanced vibration protection technology for improved performance in high-vibration environments.
  • Play well with others
    Broadly compatible with most PC and major enterprise operating systems. Specifically designed for use in enterprise-grade data centers and storage systems.
WD Gold WD4003FRYZ - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, Enterprise Class Reliability, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
101.6 mm x 147 mm x 26.1 mm
715 g
5-year warranty
4 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.6 mm
147 mm
26.1 mm
715 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
255 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7 Watt (read) , 5.9 Watt (idle)
Apple MacOS, Linux, Microsoft Windows Server, Microsoft Windows
RoHS
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine wave
Sound Emission
29 dBA
Form Factor: 3.5
Type: Hard drive
Capacity: 4TB
Brand: WD
