WD 4TB Gold 3.5" SATA 6Gb/s 7200RPM Datacenter Hard Drive
Quicklinx: C2KHWS00 Mfr#: WD4002FYYZ
  • Specifically designed for use in enterprise servers, datacenter servers, and storage systems
  • Tested for 24x7x365 reliability at workloads up to 550TB per year
  • Performance-optimized for heavy application workloads
  • 5-year limited warranty
  • Full range of nearline capacities
    From entry-level servers to high end enterprise storage systems, WD Gold hard drives offer the capacities required for the most demanding datacenter environments.
  • High workload capability
    Delivering both performance and reliability to any datacenter environment, WD Gold hard drives are designed to handle workloads up to 550TB per year which is among the highest workload capability of any 3.5-inch hard drive.
  • High level of reliability
    With up to 2.5 million hours MTBF, WD Gold hard drives deliver one of the highest levels of reliability and durability for yearly operation (24x7x365) within the most demanding storage environments.
  • Vibration Protection
    Enhanced RAFF technology includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration in real time. The result is a significant performance improvement in high vibration environments.
  • RAID-specific, time-limited error recovery (TLER)
    Reduces drive fallout caused by the extended hard drive error-recovery processes common to desktop drives.
  • Extended thermal burn-in test
    Each drive is put through extended burn-in testing with thermal cycling to ensure reliable operation.
  • Dynamic fly height technology
    Each read-write head's fly height is adjusted in real time for optimum reliability.
  • Dual actuator technology
    A head positioning system with two actuators that improves positional accuracy over the data track(s). The primary actuator provides coarse displacement using conventional electromagnetic actuator principles. The secondary actuator uses piezoelectric motion to fine tune the head positioning to a higher degree of accuracy.
  • Compatibility testing
    All WD Gold hard drives are extensively tested across a variety of popular OEM storage systems, SATA controllers, and host bus adapters, to ensure ease of integration for a plug and play solution.
WD Gold Datacenter Hard Drive WD4002FYYZ - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NAS compatible, 24x7 availability, Dynamic fly height technology, advanced format 512n
101.6 mm x 147 mm x 26.1 mm
715 g
5-year warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.6 mm
147 mm
26.1 mm
715 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
201 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
9 Watt (read) , 8.7 Watt (write) , 7 Watt (idle) , 8.8 Watt (random read)
Apple MacOS, Linux, Microsoft Windows
RoHS
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 1 ms half-sine wave
Sound Emission
29 dBA
