WD 4TB Elements USB 3.0 3.5" Desktop Hard Drive
Quicklinx: 9H00WS00 Mfr#: WDBWLG0040HBK-EESN
Form Factor: 3.5
Capacity: 4TB
Interface: SuperSpeed USB
36 In Stock
£83.67 ex VAT
£100.40 inc VAT
WD Elements USB 3.0 external hard drive is an easy-to-use, reliable way to add more storage to your PC or Macintosh. Simply plug it in to a USB port and start saving or backing up your photos, music, video, and files. It's preformatted for immediate use so there's no software or CD to load. The compact, durable metal case provides extra data protection helping keep data safe from loss.
  • Expansive storage
    With a generous 4 TB capacity, the WD Elements Desktop hard drive provides ample space for storing documents, photos, music, and video files, making it a suitable solution for personal and professional use
  • High-speed connectivity
    Equipped with USB 3.0 interface, this external hard drive offers a fast data transfer rate of up to 5.0 Gbps, allowing for quick and efficient file transfers and backups
  • Easy compatibility
    Designed to be NTFS formatted and compatible with Windows 7, the WD Elements Desktop ensures seamless integration with your existing system without the need for additional software installations
WD Elements Desktop WDBWLG0040HBK - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop)
4 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted
Power Source
Included AC adapter
48 mm x 135 mm x 165.8 mm
950 g
United Kingdom
Microsoft Certification
Compatible with Windows 7
4 TB
USB 3.0
NTFS formatted
48 mm
135 mm
165.8 mm
950 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD SmartWare Pro (30 days trial)
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable - external
Plug and Play, RoHS
United Kingdom
5 °C
35 °C
Form Factor: 3.5
Capacity: 4TB
Brand: WD
