Power-conserving WD AV-GP SATA hard drives take advantage of WD's GreenPower technology to meet the extreme requirements of demanding audio and video environments. With power reduction of up to 40%, they deliver cool and quiet operation and reliability perfect for audio video applications such as PVRs, DVRs, Set-Top Boxes (STBs) as well as surveillance video recording.
- WD AV-GP WD40EURX - hard drive - 4 TB - SATA 6Gb/s -
- Hard drive - internal - Data Lifeguard, IntelliPower, GreenPower technology, Advanced Format technology
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Data Lifeguard, IntelliPower, GreenPower technology, Advanced Format technology, S.M.A.R.T.
- 101.6 mm x 147 mm x 26.1 mm
- 680 g
- 3-year warranty
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 680 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 150 MBps
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 5.1 Watt (read) , 5.1 Watt (write) , 4.5 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
- RoHS
- Limited warranty - 3 years
- 0 °C
- 65 °C
- 5 - 95% (non-condensing)
- Shock Tolerance
- 65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
- Vibration Tolerance
- 0.75 g @ 20-300 Hz (operating) / 4 g @ 20-500 Hz (non-operating)
- Sound Emission
- 26 dBA
