WD 480GB Ultrastar SA210 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: DXH0WS00 Mfr#: 0TS1650
Form Factor: 2.5"
Capacity: 480GB
Interface: Serial ATA-600
Type: Internal hard drive
£125.75 ex VAT
£150.90 inc VAT
Built on Western Digital 64-layer 3D NAND, the Ultrastar SA210 SATA SSD is HGST's SSD purpose-built for enterprise boot and edge applications. Edge computing is pushing applications, like content delivery, away from centralized data centers and closer to those who are consuming the content. In such environments, data access speed is essential. The Ultrastar SA210 delivers up to 510MB/s sequential read throughput and 64K IOPS random read performance to unleash the full potential of your server grade system and its high-end CPU capabilities. Applications, like content delivery networks, can also benefit from higher capacity offerings.
WD Ultrastar SA210 HBS3A1948A7E6B1 - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal - LDPC error correction
480 GB
Hardware Encryption
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
100.2 mm x 69.85 mm x 7 mm
37.4 g
5-year warranty
480 GB
Hardware Encryption
2.5"
SATA 6Gb/s
100.2 mm
69.85 mm
7 mm
37.4 g
Performance
SSD Endurance
87 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
510 MBps (read) / 475 MBps (write)
4KB Random Read
64000 IOPS
4KB Random Write
5000 IOPS
Seek Time
0.15 ms (average)
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
3.8 Watt (average)
Limited warranty - 5 years
70 °C
Form Factor: 2.5"
Capacity: 480GB
Brand: WD
Price Range Ex VAT: 100 - 150
