WD 3TB AV-GP SATA 6GB/s 64MB 3.5" Hard Drive
Quicklinx: 99CCWS00 Mfr#: WD30EURX
Power-conserving WD AV-GP SATA hard drives take advantage of WD's GreenPower technology to meet the extreme requirements of demanding audio and video environments. With power reduction of up to 40%, they deliver cool and quiet operation and reliability perfect for audio video applications such as PVRs, DVRs, Set-Top Boxes (STBs) as well as surveillance video recording.
WD AV-GP WD30EURX - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliSeek, Preemptive Wear Leveling (PWL), SilkStream, IntelliPower, NoTouch ramp load technology, Advanced Format technology
101.6 mm x 147 mm x 26.1 mm
730 g
3-year warranty
3 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
730 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
145 MBps
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
4.4 Watt (active) , 0.6 Watt (idle)
RoHS
Limited warranty - 3 years
70 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
23 dBA
