WD 320GB Scorpio Black 7200RPM 16MB 2.5" SATA-300
WD Scorpio Black
Customer rating: 5.0* (Write a review)
Quicklinx: 56MXWS00 Mfr#: WD3200BEKT
Designed with top-of-the-line notebook computers in mind, this high performance drive delivers the capacity and speed needed to supercharge a notebook PC without compromising battery life or quiet acoustics. Features like these also make this drive an outstanding option for compact desktops, external hard drives, gaming systems, and blade servers.
  • Maximum performance
    Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
  • No compromises
    High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
WD Black Performance Hard Drive WD3200BEKT - hard drive - 320 GB - SATA 3Gb/s
Hard drive - internal
320 GB
2.5" x 1/8H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
Shock Guard, WhisperDrive, IntelliSeek, SecurePark, S.M.A.R.T.
70 mm x 100 mm x 9.5 mm
111 g
5-year warranty
320 GB
2.5" x 1/8H
SATA 3Gb/s
Buffer Size
16 MB
70 mm
100 mm
9.5 mm
111 g
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
100 MBps
Track-to-Track Seek Time
2 ms
Average Latency
5.5 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
RoHS
Limited warranty - 5 years
60 °C
8 - 90%
Shock Tolerance
275 g @ 2ms (operating) / 900 g @ 1ms (non-operating)
Sound Emission
22 dB
Customer reviews
Write a review for the WD 320GB Scorpio Black 7200RPM 16MB 2.5" SATA-300 here!
Good performance
Reviewed by Anonymous Review Posted 25/12/2008
I'd been running 5400 rpm drives. I installed this drive - boot time was much faster, as is time to load programs. Well worth the extra. It's slightly noisier and hotter, but worth that for the extra performance. I've had problems with some of the early 320gb 2.5" drives from other manufacturers - but so far this WD drive seems to be fine.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
