WD 3.84TB WD Gold SATA 6GB/s 2.5" U2 NVMe SSD
Quicklinx: FXZ7WS00 Mfr#: WDS384T1D0D
Add the power of NVMe to your enterprise to improve system responsiveness and boost your business productivity while lowering your overall TCO. WD Gold NVMe SSDs can work alone to handle tough workloads with endurance you can trust. Stepping up to NVMe gives your system enterprise-class features like power loss protection and high performance with low latency.
  • Enhanced reliability
    The WD Gold Enterprise-Class SSD is designed with reliability, boasting a mean time between failures (MTBF) of 2,000,000 hours. This level of reliability ensures that your data is safe and the drive is durable, even under heavy use in demanding enterprise environments.
  • High capacity storage
    With a generous 3.84 TB capacity, this solid state drive offers ample space for large-scale storage solutions, making it ideal for data centers and high-performance computing applications.
  • Efficient power management
    Featuring a power loss protection (PLP) system, the WD Gold SSD ensures the integrity of your data in the event of a sudden power outage. Additionally, its idle power consumption of just 4.94 watts contributes to a lower total cost of ownership by reducing energy costs.
  • Advanced technology
    Equipped with NVM Express (NVMe) 1.3 interface and U.2 PCIe 3.1 x4 connectivity, this SSD delivers fast data transfer speeds, enhancing overall system performance and responsiveness.
  • Secure data erasure
    The Secure Erase function provides an easy and effective way to completely erase data, ensuring that sensitive information is irretrievably deleted and cannot be recovered, making it perfect for data security compliance.
WD Gold Enterprise-Class SSD WDS384T1D0D - SSD - 3.84 TB - U.2 PCIe 3.1 x4 (NVMe)
Solid state drive - internal
3.84 TB
2.5"
Enterprise Class Reliability, Secure Erase function, Enterprise, Power Loss Protection (PLP), NVM Express (NVMe) 1.3
69.85 mm x 100.45 mm x 7 mm
95 g
5-year warranty
3.84 TB
2.5"
69.85 mm
100.45 mm
7 mm
95 g
Performance
Drive Writes Per Day (DWPD)
0.8
SSD Endurance
5.61 PB
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x PCI Express 3.1 x4 (NVMe)
Compatible Bay
2.5"
Power Consumption
4.94 Watt (idle)
Limited warranty - 5 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
