WD 2TB Ultrastar DC HA210 7200 RPM SATA 3.5" Hard Drive
Quicklinx: DTNWWS00 Mfr#: 1W10002
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
12 In Stock
£93.83 ex VAT
£112.59 inc VAT
Data centers face growing pressures to store more with flat-to-shrinking budgets. Keeping systems operational for as long as possible to maximize investments can be an effective part of the strategy, but supporting those legacy applications becomes even more challenging as drive technologies move to next generation formats and interfaces. Ultrastar 7K2 has a SATA 6Gb/s interface and native 512-byte sector size to provide high performance and compatibility with legacy data center applications. Enhanced RAFF technology in the 7K2 includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration disturbances in real time - especially helpful in multi-drive arrays and rack-mounted systems maintaining high read/write performance.
WD Ultrastar DC HA210 HUS722T2TALA604 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), Dynamic fly height technology, advanced format 512n
101.6 mm x 147 mm x 26.1 mm
640 g
5-year warranty
2 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.6 mm
147 mm
26.1 mm
640 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
200 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
8.1 Watt (active) , 5.9 Watt (idle)
RoHS 2011/65/EU
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
65 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
1.08 g @ 10-300 Hz
Vibration Tolerance (non-operating)
3.8 g @ 10-300 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 2TB
Brand: WD
