Data centers face growing pressures to store more with flat-to-shrinking budgets. Keeping systems operational for as long as possible to maximize investments can be an effective part of the strategy, but supporting those legacy applications becomes even more challenging as drive technologies move to next generation formats and interfaces. Ultrastar 7K2 has a SATA 6Gb/s interface and native 512-byte sector size to provide high performance and compatibility with legacy data center applications. Enhanced RAFF technology in the 7K2 includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration disturbances in real time - especially helpful in multi-drive arrays and rack-mounted systems maintaining high read/write performance.
                Enhanced durabilityBuilt to withstand continuous operation and equipped with Dual Stage Actuator (DSA), Dynamic fly height technology, and Enhanced Rotational Vibration Safeguard (RVS), this hard drive promises reliability and endurance under demanding data center environments.
                Optimized energy efficiencyFeaturing HelioSeal technology for lower power consumption, the WD Ultrastar DC HA210 operates at a mere 8.1 W during active use and 5.9 W during idle. This not only reduces energy costs but also contributes to a greener computing environment.
                High-capacity storageWith a 2 TB capacity, this hard drive offers ample space for large-scale storage needs, making it an ideal choice for enterprise-level data management and storage solutions.
                Robust data securityThe Secure Erase function provides an added layer of data protection, ensuring sensitive information can be completely erased when needed, offering peace of mind for data security.
                Exceptional reliabilityA mean time between failures (MTBF) of 2,000,000 hours signifies the drive's reliability and longevity, reducing the need for frequent replacements and maintenance.
- WD Ultrastar DC HA210 HUS722T2TALA604 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), Dynamic fly height technology, advanced format 512n
- 101.6 mm x 147 mm x 26.1 mm
- 640 g
- 5-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.6 mm
- 147 mm
- 26.1 mm
- 640 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 200 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 8.1 Watt (active) , 5.9 Watt (idle)
- RoHS 2011/65/EU
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 65 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 300 g @ 2 ms half-sine wave
- Vibration Tolerance (operating)
- 1.08 g @ 10-300 Hz
- Vibration Tolerance (non-operating)
- 3.8 g @ 10-300 Hz
