WD 2TB Ultrastar DC HA210 7200 RPM SATA 3.5" Hard Drive
Quicklinx: DTNWWS00 Mfr#: 1W10002
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
18 In Stock
£87.17 ex VAT
£104.60 inc VAT
Data centers face growing pressures to store more with flat-to-shrinking budgets. Keeping systems operational for as long as possible to maximize investments can be an effective part of the strategy, but supporting those legacy applications becomes even more challenging as drive technologies move to next generation formats and interfaces. Ultrastar 7K2 has a SATA 6Gb/s interface and native 512-byte sector size to provide high performance and compatibility with legacy data center applications. Enhanced RAFF technology in the 7K2 includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration disturbances in real time - especially helpful in multi-drive arrays and rack-mounted systems maintaining high read/write performance.
  • Enhanced durability
    Built to withstand continuous operation and equipped with Dual Stage Actuator (DSA), Dynamic fly height technology, and Enhanced Rotational Vibration Safeguard (RVS), this hard drive promises reliability and endurance under demanding data center environments.
  • Optimized energy efficiency
    Featuring HelioSeal technology for lower power consumption, the WD Ultrastar DC HA210 operates at a mere 8.1 W during active use and 5.9 W during idle. This not only reduces energy costs but also contributes to a greener computing environment.
  • High-capacity storage
    With a 2 TB capacity, this hard drive offers ample space for large-scale storage needs, making it an ideal choice for enterprise-level data management and storage solutions.
  • Robust data security
    The Secure Erase function provides an added layer of data protection, ensuring sensitive information can be completely erased when needed, offering peace of mind for data security.
  • Exceptional reliability
    A mean time between failures (MTBF) of 2,000,000 hours signifies the drive's reliability and longevity, reducing the need for frequent replacements and maintenance.
WD Ultrastar DC HA210 HUS722T2TALA604 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), Dynamic fly height technology, advanced format 512n
101.6 mm x 147 mm x 26.1 mm
640 g
5-year warranty
2 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.6 mm
147 mm
26.1 mm
640 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
200 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
8.1 Watt (active) , 5.9 Watt (idle)
RoHS 2011/65/EU
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
65 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
1.08 g @ 10-300 Hz
Vibration Tolerance (non-operating)
3.8 g @ 10-300 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 2TB
Brand: WD
