WD 2TB Red NAS Desktop  Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX
Quicklinx: 8601WS00 Mfr#: WD20EFRX
WD Red™: The colour of NAS.
WD Red is designed for NAS systems that have 1-8 drive bays. Available in capacities ranging from 1TB to 8TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
• Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-8 bay systems
• Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
• Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
  • Beyond desktop with NASware
    WD Red drives include WD's exclusive NASware technology that addresses many of the challenges a traditional desktop hard drive has in a NAS system. WD works directly with the partners to test compatibility and reduce thecustomer's guess work as to which drive is right for their NAS system. Designed to deliver a better customer experience in small NAS systems, this innovative firmware finely balances the most important attributes of performance, power, and reliability in multiple drive environments. The unique algorithms in NASware optimize power and performance without compromising on the attributes that NAS-system owner's value.
  • Important features for system integrators
    In addition to features that make WD Red drives perfect for populating or upgrading NAS systems, NASware brings features that system integrators need when building specialized NAS systems.
  • Save power and money
    NASware optimizes power use resulting in significant power savings and lower hard drive operating temperatures. This improves the overall reliability and performance of the drive and reduces the NAS cost of ownership.
  • Intelligent error recovery
    With built in intelligent error recovery controls, NASware also prevents hard drives from being dropped off the RAID due to extended error recovery. This provides more availability and less down time rebuilding the RAID.
  • Command completion
    To further improve reliability, NASware minimizes the data corruption or loss in the event of an unexpected power loss by completing the command in process before shutting down.
WD Red Plus NAS Hard Drive WD20EFRX - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal - IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, S.M.A.R.T.
10.2 cm x 14.7 cm x 2.6 cm
600 g
3-year warranty
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.2 cm
14.7 cm
2.6 cm
600 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
4.1 Watt (read) , 4.1 Watt (write) , 2.7 Watt (idle) , 0.4 Watt (sleep)
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
23 dBA
8601 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.24
8601 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £64.93
Resources
The following resources are available for the WD 2TB Red NAS Desktop Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX
