WD 2TB Blue Mobile 2.5" 7mm SATA 6Gb/s 128MB Cache
Quicklinx: DC44WS00 Mfr#: WD20SPZX
Form Factor: 2.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 5400rpm
£75.05 ex VAT
£90.06 inc VAT
WD Blue hard drives deliver solid performance and reliability while providing you with all of the space you need to hold enormous amounts of photos, videos, and files. WD Blue hard drives are designed for use as primary drives in notebooks and external enclosures.
  • SATA 6 Gb/s interface
    The SATA 6 Gb/s interface provides greater flexibility for use with the advanced chipsets as well as backwards compatibility to legacy systems with SATA 3 Gb/s requirements.
  • NoTouch ramp load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
  • High quality
    Built to the high standards of quality and reliability of the WD brand, these drives offer the features and capacity ideal for your everyday computing needs.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features help ensure low power consumption.
  • Quiet
    In a notebook drive, silence is golden. WD's exclusive noise reducing technologies yield some of the quietest hard drives on the market.
WD Blue WD20SPZX - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
90 g
Intel Next Unit of Computing 13 Extreme Kit - NUC13RNGi5, 13 Extreme Kit - NUC13RNGi7, 13 Extreme Kit - NUC13RNGi9
2 TB
2.5"
SATA 6Gb/s
Buffer Size
128 MB
69.85 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.7 Watt (read/write) , 0.5 Watt (idle) , 0.1 Watt (standby) , 0.1 Watt (sleep)
Software Included
Acronis True Image WD Edition
RoHS, TUV Nord, NMB-3 Class B, CAN ICES-3 Class B
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Form Factor: 2.5
Type: Hard drive
Capacity: 2TB
Brand: WD
