WD 2TB Blue 3D NAND SATA 6GB/s 2.5" SSD
SOLID STATE DRIVE WITH HIGH CAPACITIES & ENHANCED RELIABILITY
Quicklinx: D0R8WS00 Mfr#: WDS200T2B0A
Select:
WD Blue™ 3D NAND SATA SSD
A new dimension of storage
Built for enhanced reliability, WD Blue™ 3D NAND SATA SSDs offer high capacity, enhanced power efficiency, and blazing speed. Combined with 1.75M hours MTTF,4 up to 500 TBW,5 and a 3-year limited warranty, you get storage to depend on for years to come.
• 3D NAND SATA SSD for capacities up to 2TB with enhanced reliability.
• An active power draw up to 25% lower than previous generations of WD Blue SSD
• Sequential read speeds up to 560MB/s and sequential write speeds up to 530MB/s
• An industry-leading 1.75M hours mean time to failure (MTTF) and up to 500 terabytes written (TBW) for enhanced reliability.
• WD F.I.T. Lab™ certification for compatibility with a wide range of computers.
• Free downloadable software to monitor the status of your drive and clone a drive, or backup your data.
• Includes a 3-year limited warranty so upgrading your storage is worry-free.
High capacity with enhanced reliability
A WD Blue 3D NAND SATA SSD uses 3D NAND technology not only for higher capacities (up to 2TB) than the previous generation WD Blue SSDs, but also to help reduce cell-to-cell interference for enhanced reliability.
Enhanced power efficiency
Offering improved endurance, a WD Blue 3D NAND SATA SSD features an active power draw up to 25% lower than previous generations of WD Blue SSDs. And with less power used, you’re able to work longer before recharging your laptop.
Superior performance for high-end computing
For a variety of computing applications like gaming, HD media playback, or creative software, look to WD Blue 3D NAND SATA SSDs. Western Digital™ 3D NAND technology helps enable sequential read speeds up to 560MB/s and sequential write speeds up to 530MB/s for fast system boot-ups, quick application responses, and rapid transfer speeds.
Leading-edge reliability
An SSD is designed with no moving parts to help protect against data loss if it is accidentally bumped or dropped. And with 1.75M hours MTTF (mean time to failure), up to 500 TBW (terabytes written), and several error correction technologies, WD Blue 3D NAND SATA SSDs can help guard data for years to come.
Broad compatibility
With a certification from the WD Functional Integrity Testing Lab (F.I.T. Lab™), every WD Blue 3D NAND SATA SSD is verified for compatibility with a wide range of desktop and laptop computers. Every WD Blue 3D NAND SATA SSD goes through extensive compatibility and reliability testing to ensure it meets the high standards of the WD Brand.
Downloadable WD SSD Dashboard and Acronis software
Monitor your drive’s available capacity, operating temperatures, SMART attributes and more with the WD SSD Dashboard. Acronis® True Image™ WD Edition software, available as a free download, can clone drives and backup your operating system, applications, settings and all of your data.
Every WD Blue 3D NAND SATA SSD comes with a 3-year limited warranty, so you can be confident of your storage when you upgrade or replace any of your drives.
  • Leading-edge reliability
  • High capacity with enhanced reliability
    A WD Blue 3D NAND SATA SSD uses 3D NAND technology not only for higher capacities, but also to help reduce cell-to-cell interference for enhanced reliability.
  • Enhanced power efficiency
    Offering improved endurance, a WD Blue 3D NAND SATA SSD features an active power draw lower than previous generations of WD Blue SSDs. And with less power used, you're able to work longer before recharging your laptop.
WD Blue 3D NAND SATA SSD WDS200T2B0A - SSD - 2 TB - SATA 6Gb/s
Solid state drive - internal
2 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
DEVSLP SATA low power mode, 3D NAND Technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
57.9 g
5-year warranty
2 TB
2.5"
SATA 6Gb/s
69.85 mm
100.2 mm
7 mm
57.9 g
Performance
SSD Endurance
500 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 530 MBps (write)
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
60 mW (active) , 3000 mW (read) , 3800 mW (write) , 56 mW (sleep)
UL, TUV, VCCI, BSMI, FCC, WEEE, KC, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years
70 °C
Min Storage Temperature
-55 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 g @ 7-800 Hz
