WD 2TB Blue 256MB 3.5in SATA 6GB
Quicklinx: G57NWS00 Mfr#: WD20EZBX
Form Factor: 3.5
Type: Hard drive
Capacity: 2TB
Spin Speed (rpm): 7200rpm
£60.82 ex VAT
£72.98 inc VAT
WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives. Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs. These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features help ensure low power consumption.
  • NoTouch ramp load technology
    Safely positions the recording head off the disk surface to protect your data.
  • Upgrading your drive is easy
    Seamlessly migrate your current system to your new Western Digital drive using Acronis True Image WD Edition cloning software, available as a free download on the WD Support site. This software enables you to copy all your data to a new drive so you don't have to reinstall your operating system to get all the benefits of a new drive.
WD Blue WD20EZBX - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
101.6 mm x 147 mm x 26.1 mm
450 g
2 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Software Included
Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS High Sierra 10.13
Form Factor: 3.5
Type: Hard drive
Capacity: 2TB
Brand: WD
