WD 1TB Blue M.2 2280 SATA 6Gb/s Internal SSD
Quicklinx: CFNLWS00 Mfr#: WDS100T1B0B
Upgraded storage for high end performance
Ready for your high performance computing needs, a WD Blue SSD offers optimized storage with blazing speed and leading-edge reliability.
Superior Performance
With read speeds up to 545MB/s and write speeds up to 525MB/s, WD Blue SATA SSDs deliver fast system boot times and less load time.
Leading-Edge Reliability
An endurance rating of up to 400TBW and a 1.75 million hour mean time to failure ensure a WD Blue SSD can help guard your data for years to come.
Maximized Multitasking
Optimized for multitasking, WD Blue SSDs let you simultaneously run several demanding applications with ease.
The right Form Factor for your PC
Evolved for smaller and thinner computers, WD Blue SSDs are available in 2.5" 7mm and M.2 2280 models to accommodate most laptop and desktop PCs. And the downloadable WD SSD Dashboard provides a suite of tools so you’re always able to check on the health of your solid state drive.
WD F.I.T. Lab certified
Certified by WD F.I.T. Lab to be compatible with a wide range of desktop and laptop computers, you can be sure a WD Blue SSD is the right fit for you.
3-year limited warranty
Every WD Blue SSD comes with a 3-year limited warranty, so you can confidently trust WD for all your data needs.
  • Superior performance for advanced computing
    For advanced computing applications like gaming, HD media playback, or creative software, WD Blue hard drives have the speed you need for the performance you want. Tiered caching technology utilizes SLC (single-level cell) and TLC (triple-level cell) flash technology to enable high sequential read and write speeds, allowing for fast system boot up, quick application response, and rapid transfer speeds.
  • Amazing reliability
    With no moving parts, a hard drive is designed to help protect against data loss, if a drive is accidentally bumped or dropped. And with long hours MTTF (mean time to failure) and a high endurance rating, WD Blue hard drives can help guard data for years to come. WD Blue hard drives also use several error-correction technologies to help prevent data loss and provide lasting reliability.
  • Maximized multitasking
    WD Blue hard drives are optimized for multitasking and can easily run several resource-heavy applications simultaneously. Run a background virus scan while watching a 4K video and checking your email.
WD Blue PC SSD WDS100T1B0B - SSD - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
DevSleep mode, S.M.A.R.T.
22 mm x 80 mm x 1.5 mm
7 g
3-year warranty
1 TB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
1.5 mm
7 g
Performance
SSD Endurance
400 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
545 MBps (read) / 525 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
80000 IOPS
Reliability
MTBF
1,750,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
70 mW (active) , 2850 mW (read) , 4400 mW (write) , 9.7 mW (DevSleep)
Software Included
WD SSD Dashboard
UL, TUV, BSMI, FCC, KC
Limited warranty - 3 years
70 °C
Min Storage Temperature
-55 °C
Max Storage Temperature
85 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine pulse
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 g @ 7-800 Hz
