WD 1TB Blue 2.5" SATA 5400RPM Internal Hard Drive Mobile
Quicklinx: DL7YWS00 Mfr#: WD10SPZX
Form Factor: 2.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 5400rpm
£41.21 ex VAT
£49.45 inc VAT
Boost your PC storage with WD Blue drives, the brand designed just for desktop and all-in-one PCs with a variety of storage capacities.
  • An excellent solution for your everyday computing needs
    The WD Blue drive delivers performance, reliability, and capacity, making it an excellent solution for the everyday user.
  • Plan for the future
    With better technology comes bigger storage needs. Digital cameras that record video at Ultra HD resolution and 30 frames per second require a ton of storage. Handling all that media is a snap with this drive.
WD Blue WD10SPZX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
5400 rpm
Advanced Format technology
69.67 mm x 100.2 mm x 7 mm
90 g
1 TB
2.5"
SATA 6Gb/s
Buffer Size
128 MB
69.67 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Form Factor: 2.5
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: WD
