WD 18TB Gold Enterprise 7200 RPM SATA 3.5" 256MB Hard Drive
Quicklinx: FWSQWS00 Mfr#: WD181KRYZ
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 18TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£341.12 ex VAT
£409.34 inc VAT
Express delivery Order within the next 20 hours for delivery on Friday
The WD Gold is a highly reliable solution for demanding storage environments. Specifically designed for use in enterprise-class storage systems and data centers, the WD Gold Enterprise Class SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
  • Proven reliability
    Enhanced reliability with up to 2.5M hours MTBF.
  • High workload
    Take on workloads at up to 10 times the typical desktop rating.
  • Vibration protection
    Vibration protection technology gives you peace of mind.
WD Gold WD181KRYZ - hard drive - 18 TB - SATA 6Gb/s
Hard drive - internal
18 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Spindle Speed
7200 rpm
Vibration dampening, HelioSeal, 24x7 continuous operation, advanced format 512e, Energy-Assisted Magnetic Recording (EAMR), Triple State Actuator (TSA)
101.6 mm x 147 mm x 26.1 mm
690 g
Worldwide
5-year warranty
18 TB
3.5"
SATA 6Gb/s
Buffer Size
512 MB
101.6 mm
147 mm
26.1 mm
690 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
269 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.5 Watt (active) , 5.6 Watt (idle)
RoHS 2011/65/EU
Worldwide
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
50 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
250 g @ 2 ms half-sine wave
Form Factor: 3.5
Type: Hard drive
Capacity: 18TB
Brand: WD
