The WD Gold is a highly reliable solution for demanding storage environments. Specifically designed for use in enterprise-class storage systems and data centers, the WD Gold Enterprise Class SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
Proven reliability
Enhanced reliability with up to 2.5M hours MTBF. -
High workload
Take on workloads at up to 10 times the typical desktop rating. -
Vibration protection
Vibration protection technology gives you peace of mind.
- WD Gold WD181KRYZ - hard drive - 18 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 18 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 512 MB
- Spindle Speed
- 7200 rpm
- Vibration dampening, HelioSeal, 24x7 continuous operation, advanced format 512e, Energy-Assisted Magnetic Recording (EAMR), Triple State Actuator (TSA)
- 101.6 mm x 147 mm x 26.1 mm
- 690 g
- Localisation
- Worldwide
- 5-year warranty
- Capacity
- 18 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 512 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 690 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 269 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- 24x7 Operation
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.5 watt (active) , 5.6 watt (idle)
- RoHS 2011/65/EU
- Localisation
- Worldwide
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 50 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 250 g @ 2 ms half-sine wave
