The WD Gold is a highly reliable solution for demanding storage environments. Specifically designed for use in enterprise-class storage systems and data centers, the WD Gold Enterprise Class SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
                Proven reliabilityEnhanced reliability with up to 2.5M hours MTBF.
                High workloadTake on workloads at up to 10 times the typical desktop rating.
                Vibration protectionVibration protection technology gives you peace of mind.
- WD Gold WD161KRYZ - hard drive - 16 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 16 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 512 MB
- Spindle Speed
- 7200 rpm
- Vibration dampening, HelioSeal, 24x7 continuous operation, advanced format 512e, Energy-Assisted Magnetic Recording (EAMR), Triple State Actuator (TSA)
- 101.6 mm x 147 mm x 26.1 mm
- 690 g
- Localisation
- Worldwide
- 5-year warranty
- Capacity
- 16 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 512 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 690 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 262 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.5 Watt (active) , 5.6 Watt (idle)
- RoHS 2011/65/EU
- Localisation
- Worldwide
- Shipping Width
- 12.7 cm
- Shipping Depth
- 6.35 cm
- Shipping Height
- 19.05 cm
- Shipping Weight
- 830 g
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 50 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 250 g @ 2 ms half-sine wave
