Brand
WD 14TB Ultrastar DC HC530 7200 RPM SATA 3.5" 256MB Enterprise Hard Drive
Quicklinx: DXJ2WS00 Mfr#: 0F31284
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-150
Capacity: 14TB
Spin Speed (rpm): 7200rpm
34 in stock
£402.99 ex VAT
£483.58 inc VAT
The breadth and depth of big data is driving the universal need for higher capacities across a broad spectrum of applications and workloads. Laying the foundation for a worryfree data center, Western Digital delivers capacity to conquer the data explosion - the Ultrastar DC HC530 hard drive. Built using HelioSeal technology, the fifth generation helium platform and the basis for the high-capacity DC HC500 series, Ultrastar DC HC530 was designed for public and private cloud environments where storage density, Watts/TB and $/TB are critical parameters for creating a cost-efficient infrastructure. HelioSeal technology is key to achieving higher drive capacities, higher reliability ratings and extreme power efficiency for lower levels of total cost of ownership (TCO) for cloud and enterprise customers.
  • Driving up capacity and driving down TCO for cloud and enterprise data centers
  • HelioSeal technology helps solve challenges facing next generation data centers
    Data centers are facing growing pressures. Data volume is expanding, operating costs are rising, yet budgets remain flat. HelioSeal technology enables Ultrastar DC HC530 to deliver low power profiles, helping data center architects meet eco-environmental goals and requirements. The Ultrastar DC HC530 is based on conventional magnetic recording (CMR) technology for drop-in simplicity in enterprise and cloud data centers. Features like TDMR technology (two-dimensional magnetic recording) and a third-generation dualstage microactuator work together to enhance head-positioning accuracy and deliver better performance, data integrity and overall drive reliability, critical in multi-drive environments where operational vibration is present.
  • Data durability and data security features to support compliance and privacy requirements
    As drive capacity grows beyond single-digit TBs, object storage systems with erasure coding generally provide better data durability compared to RAID systems, given its tolerance for simultaneous error conditions. The Ultrastar DC HC530 is ideal for object storage implementations with its massive capacity and an unbeaten reliability rating. Compliance and privacy requirements drive the need for increased data security.
WD Ultrastar DC HC530 WUH721414ALE6L4 - hard drive - 14 TB - SATA
Hard drive - internal (desktop)
14 TB
3.5" (in 3.5" carrier)
SATA
Buffer Size
512 MB
Spindle Speed
7200 rpm
HelioSeal, 512 emulation ( 512e )
101.6 mm x 147 mm x 26.1 mm
690 g
5 years warranty
14 TB
3.5"
SATA
Buffer Size
512 MB
101.6 mm
147 mm
26.1 mm
690 g
Performance
Internal Data Rate
255 MBps (read) / 267 MBps (write)
Seek Time
7.5 ms (average)
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA - 7 pin Serial ATA
Compatible Bay
3.5" or 3.5" (with included bay adapter)
Power Consumption
6 Watt (typical) , 5.5 Watt (idle)
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
0.67 g @ 5-500 Hz
Vibration Tolerance (non-operating)
1.04 g @ 2-200 Hz
Sound Emission
36 dBA
Form Factor: 3.5"
Type: Hard drive
Capacity: 14TB
Brand: WD
Stock Status: In stock
