WD 14TB Red Plus 512MB CMR 3.5in
Quicklinx: G57SWS00 Mfr#: WD140EFGX
Form Factor: 3.5
Type: Hard drive
Capacity: 14TB
Spin Speed (rpm): 7200rpm
£365.65 ex VAT
£438.78 inc VAT
Marketing description is not available.
  • For small or medium businesses
    Stream, backup, share, and organize your digital content with a NAS and WD Red Plus drives designed to effortlessly share content with the devices at your home or business. NASware 3.0 technology increases your drives' compatibility with your existing network and devices.
  • Exclusive NASware 3.0
    Not just any drive will do. Get up to 112TB of capacity in your 8-bay NAS system and with Western Digital's exclusive NASware 3.0 technology, you can optimize each and every drive. Built into every WD Red Plus hard drive, NASware 3.0's advanced technology improves storage performance by increasing compatibility, integration, upgradeability, and reliability.
  • Built for optimum NAS compatibility
    WD Red Plus drives with NASware technology takes the guesswork out of selecting a drive. Optimized for NAS systems, unique algorithm balances performance and reliability in NAS and RAID environments. Simply put, a WD Red Plus drive is one of the most compatible drives available for NAS enclosures. But don't take word for it. WD Red Plus drives are a reflection of extensive NAS partner technology engagement and compatibility-testing.
  • 3D Active Balance Plus
    The enhanced dual-plane balance control technology significantly improves the overall drive performance and reliability. Hard drives that are not properly balanced may cause excessive vibration and noise in a multi-drive system, reduce the hard drive life span, and degrade the performance over time.
  • 24/7 environment
    Since your NAS system is always on, a reliable drive is essential. With an MTBF of up to 1 million hours, the WD Red Plus drive is engineered to tackle 24x7 environments.
  • Desktop drives vs. WD Red Plus
    Do right by your NAS and choose the drive purpose-built for NAS with an array of features to help preserve your data and maintain optimum performance. Take the following into consideration when choosing a hard drive for your NAS: Compatibility: Unlike desktop drives, these drives are specifically tested for compatibility with NAS systems for optimum performance. Reliability: The always-on environment of a NAS or RAID is a hot one, and desktop drives aren't typically designed and tested under those conditions like WD Red Plus drives are. Error Recovery Controls: WD Red Plus NAS hard drives are specifically designed with RAID error recovery control to help reduce failures within the NAS system. Noise and Vibration Protection: Designed to operate solo, desktop drives typically offer little or no protection from the noise and vibration present in a multi-drive system. WD Red Plus drives are designed to thrive in multi-bay NAS system environments.
WD Red Plus WD140EFGX - hard drive - 14 TB - SATA 6Gb/s
Hard drive - internal
14 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Advanced Format technology, NASware technology, 3D Active Balance Plus, 24x7 continuous operation, Conventional magnetic recording (CMR), workload up to 180 TB per year
101.6 mm x 147 mm x 26.1 mm
690 g
3-year warranty
14 TB
3.5"
SATA 6Gb/s
Buffer Size
512 MB
101.6 mm
147 mm
26.1 mm
690 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.5 watt (read/write) , 3 watt (idle) , 0.8 watt (standby) , 0.8 watt (sleep)
RoHS 2011/65/EU
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Sound Emission
20 dBA
Form Factor: 3.5
Type: Hard drive
Capacity: 14TB
Brand: WD
