WD 14TB Red NAS Hard Drive 3.5" 256MB Cache
Quicklinx: FJ4MWS00 Mfr#: WD140EFFX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Capacity: 14TB
Spin Speed (rpm): 5400rpm
£307.28 ex VAT
£368.73 inc VAT
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
  • Compatible
    Tested with a wide range of NAS systems for optimum performance and compatibility.
  • Reliable
    Designed to operate in the always-on environment of a NAS or RAID configuration.
  • High capacity
    The high capacity allows the flexibility to build the optimal NAS solution.
WD Red Plus NAS Hard Drive WD140EFFX - hard drive - 14 TB - SATA 6Gb/s
Hard drive - internal
14 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Spindle Speed
5400 rpm
Advanced Format technology, NAS compatible, NASware technology, 24x7 availability, workload up to 180 TB per year
101.6 mm x 147 mm x 26.1 mm
690 g
3-year warranty
14 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
512 MB
101.6 mm
147 mm
26.1 mm
690 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
6.5 Watt (read/write) , 3 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
RoHS, Directive 2011/65/EU
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Sound Emission
20 dBA
Type: Hard drive
Capacity: 14TB
Brand: WD
Stock Status: In stock
