Conquer tough workloads with enterprise-class WD Gold HDDs. This highly reliable solution for demanding storage environments provides up to 2.5M hours MTBF, vibration protection technology and a low power draw thanks to HelioSeal technology. Specifically designed for use in enterprise-class data centers and storage systems, the WD Gold SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
Beyond expectations
WD Gold hard drives are performance-optimized for heavy application workloads. The WD Gold HDD's wide capacity range solves for the most demanding storage environments. -
Enhanced reliability
With up to 2.5M hours MTBF, WD Gold hard drives deliver enhanced levels of dependability and durability. -
A world-class performer
Delivering excellent service to any storage environment, WD Gold hard drives are designed to handle workloads up to 550TB per year - among the highest of any 3.5-inch hard drive. -
Vibration protection
WD Gold has sophisticated monitoring electronics that help correct linear and rotational vibrations in real time using enhanced vibration protection technology for improved performance in high-vibration environments. -
Play well with others
Broadly compatible with most PC and major enterprise operating systems. Specifically designed for use in enterprise-grade data centers and storage systems.
- WD Gold DC HA750 Enterprise Class SATA HDD WD141KRYZ - hard drive - 14 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 14 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 512 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), HelioSeal, advanced format 512e
- 101.6 mm x 147 mm x 26.1 mm
- 690 g
- Localisation
- Worldwide
- 5-year warranty
- Capacity
- 14 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 512 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 690 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 267 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6 Watt (active) , 5.5 Watt (idle)
- OS Required
- Linux, Microsoft Windows Server, Microsoft Windows
- RoHS
- Localisation
- Worldwide
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 300 g @ 2 ms half-sine wave
