My Book desktop storage is optimized for the best possible data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to save and access files up to 3x faster than with USB 2.0. My Book offers complete backup options with WD SmartWare Pro software for local and cloud backup and Acronis True Image WD Edition software for system level backup. Gain peace of mind knowing that your data is protected from unauthorized access with password protection and hardware encryption. WD's Windows 8 app makes it easy to discover the digital media stored on your My Book drive with your Windows 8 computer. Your content is automatically displayed and organized so you can easily locate and enjoy your photos, videos and music. With this drive you get connectivity with the latest USB 3.0 devices as well as backward compatibility with USB 2.0 devices. With up to 6 TB capacity, there's plenty of room to store and protect your precious memories and important files. Use WD Security to set password protection and hardware encryption. Gain peace of mind knowing that your data is protected from unauthorized access.
Ultra-fast transfer rates
My Book desktop storage is optimized for the best possible data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to save and access files up to 3x faster than with USB 2.0. -
Complete backup for peace of mind
My Book offers complete backup options with WD SmartWare Pro software for local and cloud backup and Acronis True Image WD Edition software for system level backup. -
Keep your private stuff private
Gain peace of mind knowing that your data is protected from unauthorized access with password protection and hardware encryption. -
Works great with Windows 8
WD's Windows 8 app makes it easy to discover the digital media stored on your My Book drive with your Windows 8 computer. Your content is automatically displayed and organized so you can easily locate and enjoy your photos, videos and music. -
System-level backup
Acronis True Image WD Edition is an integrated software suite that ensures security of all information on your PC. It can back up the entire disk drive or selected partitions, including your operating system, applications, settings and all of your data. You can also use the software to securely delete any confidential data you no longer need. -
Automatic backup software
WD SmartWare Pro automatic backup software works quietly in the background to help protect your data using minimal PC resources. Select automatic continuous backup to instantly create a second copy of your files. Or select the scheduled backup option to back up your files on your schedule and take control of your backup. -
Local and cloud backup
WD SmartWare Pro lets you choose. Back up your files to your My Book drive or back up your files to the cloud using your Dropbox account. You can also back up files from your Dropbox account to your My Book drive for extra protection. -
Universal connectivity
With this drive you get connectivity with the latest USB 3.0 devices as well as backward compatibility with USB 2.0 devices. -
Massive capacity
- WD My Book Pro WDBDTB0120JSL - hard drive array
- Hard drive array
- Black and silver
- Total Array Capacity
- 12 TB
- Interface
- USB 3.0, Thunderbolt 2
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Localisation
- Middle East, Africa, Europe
- Storage Controller
- RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 6 TB HDD - hot-swap - Apple Time Machine compatible, HFS+ formatted, toolless
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
- Power
- AC 120/230 V - 50/60 Hz
- 10.86 cm x 21.61 cm x 14.78 cm
- 3.57 kg
- 3-year warranty
- Hard drive array
- Enclosure Colour
- Black and silver
- Localisation
Chassis
- 2
- Supported Devices / Modules Qty
- 2
Storage
- 12 TB
- HDD Array External Interface
- CPU
- Xeon
Storage Controller
- RAID
- Data Transfer Rate
- 435 MBps
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 6 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B , 2 x Thunderbolt 2
- OS Required
- Cables Included
- 1 x USB 3.0 cable , 1 x Thunderbolt cable - 1 m
- Software Included
- WD Drive Utilities
- RoHS
- Power Device
- External power adapter
- Voltage Required
- 10.86 cm
- 21.61 cm
- 14.78 cm
- 3.57 kg
- Limited warranty - 3 years
- 0 °C
- 35 °C
