WD 12TB Gold Enterprise Class 3.5" SATA 6Gb/s 7200RPM 256MB
Quicklinx: D4F1WS00 Mfr#: WD121KRYZ
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 12TB
Spin Speed (rpm): 7200rpm
24 In Stock
£235.75 ex VAT
£282.90 inc VAT
Featuring up to ten times the workload capacity of desktop drives, WD Gold hard drives are designed from the ground up for enterprise-class reliability, capacity, power efficiency and performance.
  • High workload rating
    Delivering dependable performance to any storage environment, WD Gold hard drives are designed with a workload rating up to 12 TB per year, among the highest of any 3.5-inch hard drive.
  • Enterprise-class storage to rely on
    With up to 2.5 million hours MTBF, WD Gold hard drives deliver reliability and durability, are built for yearly operation (24 x 7x 365) within the most demanding storage environments.
  • HelioSeal Technology
    Featured in over 15 million Western Digital hard drives shipped, HelioSeal technology allows for higher capacities and less turbulence on large storage arrays. And now on its 4th generation design, HelioSeal technology is field-tested and proven to deliver high capacity, reliability, and power efficiency you can trust.
WD Gold WD121KRYZ - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
101.6 mm x 147 mm x 26.1 mm
660 g
5-year warranty
12 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
147 mm
26.1 mm
660 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
205 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7 Watt (read) , 6.8 Watt (write) , 6.9 Watt (random read) , 5 Watt (idle)
Apple MacOS, Linux, Microsoft Windows Server, Microsoft Windows
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 1 ms half-sine wave
Sound Emission
20 dBA
Form Factor: 3.5
Type: Hard drive
Capacity: 12TB
Brand: WD
