Laying the foundation for a worry-free data center, HGST delivers an amazing hard drive - Ultrastar He10. The He10 uses PMR technology and is the drive that is drop-in ready for any enterprise-capacity application or environment. It offers low power profile to help data center architects meet eco-environmental goals and requirements. The He10 provides high reliability rating. The Ultrastar He10 delivers more capacity, more efficiency, more reliability and more value to your data center.
HelioSeal technology helps solve challenges facing next generation data centers
Data centers are facing growing pressures. Data volume is expanding, operating costs are rising, yet budgets remain flat. Lowering the total cost of ownership (TCO) has become the focus of data center architects and the Ultrastar DC HC510 provides great value proposition and storage efficiency. The features include a second-generation, dual-stage actuator - the Western Digital Micro-Actuator - enhancing head-positioning accuracy to deliver better performance, data integrity and overall drive reliability, especially in multi-drive environments where operational vibration is present. -
Data durability and security with high quality and reliability
As drive capacity grows beyond single-digit TBs, object storage systems with erasure coding provide better data durability compared to RAID systems, given its tolerance for simultaneous errors conditions. Ultrastar DC HC510 is a best-fit for object storage implementations given its massive capacity and an amazing reliability rating. Compliance and privacy requirements drive the need for increased data security.
- WD Ultrastar DC HC510 HUH721010ALE604 - hard drive - 10 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), advanced format 512e, Dynamic fly height technology
- 101.6 mm x 147 mm x 26.1 mm
- 660 g
- 5-year warranty
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 512
- 101.6 mm
- 147 mm
- 26.1 mm
- 660 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 249 MBps
- Seek Time
- 8 ms (average) / 8.6 ms (max)
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.8 Watt (active) , 5 Watt (idle)
- RoHS 2011/65/EU
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 300 g @ 2 ms half-sine wave
- Vibration Tolerance (operating)
- 0.67 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
- 1.04 g @ 2-200 Hz
