WD 10TB Purple 3.5" SATA 6Gb/s 7200RPM 256MB Surveillance Drive
Quicklinx: FM1BWS00 Mfr#: WD102PURZ
Western Digital puts products through extensive Functional Integrity Testing (F.I.T.) prior to any product launch. This testing ensures products consistently meet the highest quality and reliability standards of the Western Digital brand. Western Digital also has a detailed Knowledge Base with more than 1,000 helpful articles as well as software and utilities.
WD Purple drives are built for 24/7, always-on, high-definition security systems. WD Purple surveillance hard drives feature Western Digital's exclusive AllFrame technology, so you can confidently create a security system tailored to the needs of your business. Using AllFrame technology, WD Purple drives improve video capturing and help to reduce errors, pixelation, and video interruptions that can occur in a video recorder system. WD Purple drives have an enhanced workload rating that supports systems designed for 24x7 video recording with up to 64 cameras.
  • Industry-leading storage
    Western Digital is a worldwide leader in the hard drive industry. With WD Purple surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you're protecting loved ones or monitoring your business, WD Purple offers performance you can trust.
  • Western digital's exclusive AllFrame technology
    All WD Purple drives are equipped with AllFrame technology, which improves ATA streaming to help reduce frame loss, improve overall video playback, and increase the number of hard drive bays supported within a NVR. Make your surveillance solution future-ready knowing that WD Purple drives are ready for ultra-high definition cameras. WD Purple capacities up to 6TB feature AllFrame 4K technology enabling high quality recording for up to 64 cameras. WD Purple 8TB, 10TB, 12TB & 14TB capacities feature AllFrame AI technology that enables not only recording up to 64 cameras, but also supports an additional 32 streams for Deep Learning analytics within the system.
  • Enhanced workload ratings
    WD Purple drives with AllFrame 4K technology feature a workload rating of up to 180TB/year - up to three times that of desktop drives - to handle the unique demands of modern video surveillance DVR and NVR systems. WD Purple drives with AllFrame AI technology feature a workload rating up to 360TB/year to support the Deep Learning analytics that is featured in AI capable NVRs.
  • Expand your view to 64
    Each WD Purple drive is optimized to support up to 64 cameras. With so many options, you have the flexibility to upgrade or expand your security system in the future.
  • Designed for Today's and Tomorrow's Surveillance Solutions
    With an MTBF of up to 1.5 million hours¹, WD Purple drives are engineered for mainstream surveillance DVRs and NVRs that operate 24/7. With support for more than eight bays² and tarnish resistant components², WD Purple drives deliver reliable operation in large scale surveillance systems in harsh environments.
  • Field-proven high capacity
    Now on its 5th generation, field-proven HelioSeal technology delivers trusted high capacity WD Purple storage (10TB, 12TB, and 14TB) for the massive storage needs of 4K surveillance video and Deep Learning analytics.
  • Wide compatibility
    WD Purple hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of industry leading enclosures and chipsets supported, you're sure to find the DVR or NVR configuration that's right for you.
  • Low power, high efficiency
    With exclusive IntelliSeek technology, WD Purple drives are able to calculate optimum seek speeds. This keeps power consumption low so ambient noise and vibrations are at a minimum.
WD Purple WD102PURZ - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Advanced Format technology, HelioSeal, surveillance system compatible, 24x7 continuous operation, AllFrame AI
101.6 mm x 147 mm x 26.1 mm
660 g
Worldwide
3-year warranty
10 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
660 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
265 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6 Watt (read) , 9 Watt (write) , 8 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
RoHS, Directive 2011/65/EU
Worldwide
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
20 dBA
