The Capacity Gauge (inner LED) consists of six sections which illuminate in a clockwise direction to indicate space used on the drive. Each section represents approximately 17 percent of disk space. The power/activity and capacity gauge LEDs are two concentric rings on the front panel of the drive. The outer ring is the power/activity LED and the inner ring is the capacity gauge LED.
- WD My Book Pro WDBDTB0100JSL - hard drive array
- Hard drive array
- Black and silver
- Total Array Capacity
- 10 TB
- Interface
- USB 3.0, Thunderbolt 2
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Localisation
- Middle East, Africa, Europe
- Storage Controller
- RAID RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 5 TB HDD - hot-swap - Apple Time Machine compatible, HFS+ formatted, toolless
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
- Power
- AC 120/230 V - 50/60 Hz
- 10.86 cm x 21.61 cm x 14.78 cm
- 3.57 kg
- 3-year warranty
- Hard drive array
- Enclosure Colour
- Black and silver
- Localisation
Chassis
- 2
- Supported Devices / Modules Qty
- 2
Storage
- 10 TB
- HDD Array External Interface
- CPU
- Xeon
Storage Controller
- RAID
- Data Transfer Rate
- 435 MBps
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 5 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B , 2 x Thunderbolt 2
- OS Required
- Cables Included
- 1 x USB 3.0 cable , 1 x Thunderbolt cable - 1 m
- Software Included
- WD Drive Utilities
- RoHS
- Power Device
- External power adapter
- Voltage Required
- 10.86 cm
- 21.61 cm
- 14.78 cm
- 3.57 kg
- Limited warranty - 3 years
- 0 °C
- 35 °C
