WD 10TB My Book Pro 2-bay RAID Storage (2x5TB) USB3.0 Thunderbolt NAS
Quicklinx: BM5KWS00 Mfr#: WDBDTB0100JSL-EESN
The Capacity Gauge (inner LED) consists of six sections which illuminate in a clockwise direction to indicate space used on the drive. Each section represents approximately 17 percent of disk space. The power/activity and capacity gauge LEDs are two concentric rings on the front panel of the drive. The outer ring is the power/activity LED and the inner ring is the capacity gauge LED.
WD My Book Pro WDBDTB0100JSL - hard drive array
Hard drive array
Black and silver
Total Array Capacity
10 TB
USB 3.0, Thunderbolt 2
2 (installed) / 2 (max)
Middle East, Africa, Europe
Storage Controller
RAID RAID RAID 0, 1, JBOD
Hard Drive
2 x 5 TB HDD - hot-swap - Apple Time Machine compatible, HFS+ formatted, toolless
Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
AC 120/230 V - 50/60 Hz
10.86 cm x 21.61 cm x 14.78 cm
3.57 kg
3-year warranty
Hard drive array
Enclosure Colour
Black and silver
Chassis
2
Supported Devices / Modules Qty
2
Storage
10 TB
HDD Array External Interface
CPU
Xeon
Storage Controller
RAID
Data Transfer Rate
435 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 5 TB
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B , 2 x Thunderbolt 2
1 x USB 3.0 cable , 1 x Thunderbolt cable - 1 m
Software Included
WD Drive Utilities
RoHS
External power adapter
10.86 cm
21.61 cm
14.78 cm
3.57 kg
Limited warranty - 3 years
35 °C
