WD Gold hard drives employ advanced technology to deliver great reliability, capacity, power efficiency and performance. Designed for a multitude of datacenter-specific applications, WD Gold hard drives are perfect for high-availability server and storage arrays that demand robust storage device.
High level of reliability
WD Gold hard drives deliver high levels of reliability and durability for yearly operation within the most demanding storage environments. -
RAID-specific, time-limited error recovery
Reduces drive fallout caused by the extended hard drive error-recovery processes common to desktop drives. -
Dynamic fly height technology
A head positioning system with two actuators that improves positional accuracy over the data track(s). The primary actuator provides coarse displacement using conventional electromagnetic actuator principles. The secondary actuator uses piezoelectric motion to fine tune the head positioning to a higher degree of accuracy.
- WD Gold Datacenter Hard Drive WD101KRYZ - hard drive - 10 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NAS compatible, advanced format 512e, 24x7 availability, Dynamic fly height technology
- 101.6 mm x 147 mm x 26.1 mm
- 660 g
- 5-year warranty
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 147 mm
- 26.1 mm
- 660 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 249 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 7.1 Watt (read) , 6.7 Watt (write) , 5 Watt (idle) , 6.8 Watt (random read)
- OS Required
- Apple MacOS, Linux, Microsoft Windows Server, Microsoft Windows
- RoHS, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 300 g @ 1 ms half-sine wave
- Sound Emission
- 20 dBA
