WD 1.92TB Ultrastar SA210 M.2 2280 SATA 6Gb/s SSD
Quicklinx: DXGRWS00 Mfr#: 0TS1657
Built on Western Digital 64-layer 3D NAND, the Ultrastar SA210 SATA SSD is HGST's SSD purpose-built for enterprise boot and edge applications. Edge computing is pushing applications, like content delivery, away from centralized data centers and closer to those who are consuming the content. In such environments, data access speed is essential. The Ultrastar SA210 delivers up to 510 MB/s sequential read throughput and 64K IOPS random read performance to unleash the full potential of your server grade system and its high-end CPU capabilities. Applications, like content delivery networks, can also benefit from higher capacity offerings.
  • Robust durability
    Designed to withstand the demands of both high and low operational temperatures, the WD Ultrastar SA210 operates reliably between 0°C and 70°C. Its solid state drive technology, coupled with an impressive MTBF of 2,000,000 hours, ensures long-term dependability for critical data storage.
  • Enhanced security
    The WD Ultrastar SA210 solid state drive comes equipped with advanced encryption features, including Self-Encrypting Drive (SED) technology and TCG Opal Encryption 2.01. This hardware encryption ensures that your data remains secure against unauthorized access, providing peace of mind for sensitive information storage.
  • High-speed performance
    With an internal data rate of up to 510 MBps for reading and 475 MBps for writing, alongside a data transfer rate of 600 MBps, this internal hard drive delivers swift and efficient performance. The inclusion of LDPC error correction further enhances data integrity and reliability during high-speed transactions.
WD Ultrastar SA210 HBS3A1919A4M4B1 - SSD - 1.92 TB - SATA 6Gb/s
Solid state drive - internal
1.92 TB
Hardware Encryption
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
22 mm x 80 mm x 2.38 mm
7 g
5-year warranty
1.92 TB
Hardware Encryption
M.2 2280
SATA 6Gb/s
22 mm
80 mm
2.38 mm
7 g
Performance
SSD Endurance
350 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
510 MBps (read) / 475 MBps (write)
Maximum 4KB Random Write
5000 IOPS
Maximum 4KB Random Read
64000 IOPS
Seek Time
0.15 ms (average)
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x M.2 Card - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
3.8 Watt (average)
Limited warranty - 5 years
70 °C
