WatchGuard Technologies XTM 25 and 1 Year Security Bundle
Quicklinx: 81DYWS00 Mfr#: WG025031
The WatchGuard XTM 25 Security Bundle includes the next-generation XTM 25 appliance plus a full suite security subscriptions to boost protection in critical attack areas. Subscriptions include Application Control, Intrusion Prevention Service, WebBlocker, spamBlocker, Gateway AV, and Reputation Enabled Defense. Ideal for small businesses and remote offices, the XTM 25 has up to 240 Mbps firewall throughput and five 1-Gig interfaces. Management tools include intuitive centralized console and web UI for handy anywhere-anytime management tasks.
  • Fireware XTM included
    The Fireware XTM OS increases security and networking capabilities. When you're ready, it's easy to upgrade to the Pro version of the OS for even more features.
  • Affordable security for small business
    Comprehensive network protection at a digestible price point - your network and your bottom line should be pretty happy about that.
  • Wireless security with guest access
    Everyone loves wireless. With dual-band 802.11n the 2 Series delivers reliable wireless connectivity while allowing you to provide controlled Internet access to guest users without compromising security.
  • 3 ways to manage your appliance
    Now you have the power to choose how you manage your WatchGuard appliance including, WatchGuard System Manager, the command line interface, and a web UI for access from anywhere, anytime.
  • Green security
    The firewalls are designed with efficiency in mind, consuming very little energy. Compare the power consumption to other security products and see how WatchGuard can make your data center more energy efficient. Green up your network with WatchGuard.
  • Hardware-less upgrades
    WatchGuard won't make you buy new hardware as your security demands grow. You can use simple software license keys to add functionality and increase protection as your network requires it.
  • Reporting in the Browser
    Provides a web-based, customizable reports portal designed to be hosted with direct Internet access for easy report selection and viewing.
  • Skype blocking
    Block Skype connections to and from protected hosts to keep productivity high and prevent malware injections and data leakage.
  • Self health monitoring
    Health monitoring for the WSM logging and reporting system helps minimize disruptions and maintain high service levels in these critical functions.
WatchGuard XTM 2 Series 25 - security appliance - with 1 year Gateway AV/IPS, Application Control, spamBlocker, WebBlocker, Reputation Enabled Defense, 24X7 Support Subscriptions
Security appliance
Bundled Services
External
Ports Qty
5
Performance
Firewall throughput: 240 Mbps , VPN throughput: 40 Mbps
Virtual interfaces (VLANs): 20 , Concurrent sessions: 10000 , Branch office VPN tunnels: 10 , Mobile IPSec VPN tunnels: 5 , Mobile SSL VPN tunnels: 1 , Nodes (LAN IPs): unlimited
VoIP Protocols
H.323, SIP
19 cm x 15.5 cm x 3.2 cm
Security appliance
Bundled Services
Built-in Devices
Status LCD
19 cm
15.5 cm
3.2 cm
External
Ports Qty
5
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, PPPoE, SMTP, FTP, DNS, POP3
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS
Performance
Status Indicators
Power, status, link/activity
DoS attack prevention, dynamic DNS server, Quality of Service (QoS), VPN failover, DHCP server, reset button, DHCP relay, DHCP client
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
SecurID, VASCO token authentication, XAUTH (RADIUS, LDAP, Active Directory)
IP Telephony
VoIP Protocols
H.323, SIP
1 x console , 1 x management , 5 x 1000Base-T - RJ-45
Mounting Kit
Included
CB, CSA NRTL/C, RoHS, FIPS 140-2, WEEE, EAL 4+, REACH
External power adapter
23 Watt
10 - 85% (non-condensing)
