WatchGuard Technologies Firebox X20e Edge Wireless UTM
Quicklinx: 568YWS00 Mfr#: WG50028
Get everything you need for comprehensive Unified Threat Management for your small business/remote office with the Firebox X Edge e-Series UTM Bundle. An exceptional value, each package includes; Firebox X Edge e-Series appliance; Gateway AV/IPS (1 year); spamBlocker (1 year); WebBlocker (1 year); LiveSecurity Service (1 year).
From initial purchase through ongoing security management, the Firebox X Edge e-Series UTM Bundle streamlines network security management while providing powerful network protection. Buy together and save!
WatchGuard Firebox X Edge e-Series X20e-w UTM Bundle - security appliance - Wi-Fi - with 1 year Gateway AV/IPS, spamBlocker, WebBlocker, LiveSecurity Service Subscribtions
Security appliance
Bundled Services
External
1 x ARM XScale 266 MHz
RAM
128 MB
Flash Memory
64 MB
Ports Qty
6
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Performance
Firewall throughput: 100 Mbps , VPN throughput: 35 Mbps
Security zones: 2 , Concurrent sessions: 8000 , Nodes (LAN IPs): 30 , Branch office VPN tunnels: 15 , Mobile user VPN tunnels: 5 , Authenticated users (internal database): 200
26.9 cm x 16.5 cm x 18.5 cm
0.9 kg
1-year warranty
Security appliance
Bundled Services
Built-in Devices
Status LCD
26.9 cm
16.5 cm
18.5 cm
0.9 kg
Processor / Memory / Storage
Processors Installed
RAM
128 MB
Flash Memory
64 MB
External
Ports Qty
6
Wireless, wired
Cable(s) / Media Type Supported
Network cable
Network / Transport Protocol
PPTP, IPSec, PPPoE
Routing Protocol
Static IP routing
Performance
Status Indicators
Power, status, link/activity
Firewall protection, routing, Layer 2 switching, DHCP support, NAT support, hardware encryption, PAT support, Syslog support, Stateful Packet Inspection (SPI), VPN passthrough, URL filtering, Quality of Service (QoS)
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1
Authentication Method
LDAP, Active Directory
Aerial
Antenna Qty
2
1 x management - DB-9 , 6 x 100Base-TX - RJ-45
1 x network cable
RoHS
External power adapter
12 Watt
Limited warranty - 1 year , New releases update - 1 year
45 °C
10 - 85%
