WatchGuard Technologies Firebox M470 with 3-Year Basic Security Suite
Quicklinx: FRJ5WS00 Mfr#: WGM47033#NQ-388480
WatchGuard Firebox M470 appliances combine strong security, high performance, and flexible management tools in one affordable solution for midsize businesses and distributed enterprises. The M470 delivers firewall throughput of 19.6 Gbps to keep traffic moving, with the best UTM throughput in its class - up to 3.1 Gbps - even with strong security enabled. Includes 8 1G ports, plus 1 SFP port for fiber or copper. Optional 4x10 Gb Fiber, 8x1 Gb Fiber, and 8x1 Gb Copper network interface modules enable flexible configurations. Flexible management tools give administrators access to security capabilities from an intuitive console, scriptable CLI, and web UI.
  • Always know, what's happening on your network
    WatchGuard understands the importance of network visibility and continues to deliver excellent solutions, that help customers detect harmful activities, before they become massive problems. With WatchGuard you can pinpoint significant network activities to take immediate corrective or diagnostic actions directly from the interactive, real-time monitoring.
  • Total protection
    Every network needs a full arsenal of scanning engines to protect against spyware, viruses, malicious apps, data leakage, botnets and more. WatchGuard's network security platform not only provides the complete suite of unified security controls, but offers solutions for addressing evolving network threats.
  • Easily deploy and manage many appliances
    Distributed organizations will especially appreciate the intuitive tools, that support policy creation, management and enforcement across multiple locations. Avoid having network administrators onsite to configure remote devices with WatchGuard's zero-touch RapidDeploy feature. RapidDeploy saves time and resources on initial configuration and deployment of network security.
WatchGuard Firebox M470 - security appliance - with 3 years Basic Security Suite
Security appliance
Bundled Services
External - 1U
Ports Qty
8
Performance
Firewall throughput: 19.6 Gbps , Firewall throughput (IMIX): 5.6 Gbps , VPN throughput: 5.2 Gbps , VPN throughput (IMIX): 1.8 Gbps , HTTPS throughput: 2 Gbps , Antivirus throughput: 3.5 Gbps , IPS throughput: 5.7 Gbps , Unified Threat Management (UTM) throughput: 3.1 Gbps
Concurrent connections: 3800000 , Concurrent connections (proxy): 310000 , New connections per second: 82000 , Virtual interfaces (VLANs): 300 , Authenticated users: unlimited , Branch office VPN tunnels: 250 , Mobile VPN tunnels: 250 , TDR host sensors: 250 , Priority queues: 8
VoIP Protocols
H.323, SIP
Rack mount kit
AC 120/230 V
42.8 cm x 32 cm x 4.4 cm
Security appliance
Bundled Services
Height (Rack Units)
1U
42.8 cm
32 cm
4.4 cm
External
Ports Qty
8
Wired
Network / Transport Protocol
TCP/IP, UDP/IP, PPPoE, SMTP, FTP, DHCP, DNS, POP3, IMAP, DDNS
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
NAT support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), Deep Packet Inspection (DPI), HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, DHCP relay, DHCP client, proxy firewall, WAN load balancing, Server Load Balancing (SLB), Reputation Enabled Defense, TCP/UDP proxy
Encryption Algorithm
DES, Triple DES, RSA, IKE, 128-bit AES, 256-bit AES, IKEv2, SHA-2
Authentication Method
SecurID, RADIUS, LDAP, internal user database, Active Directory, VASCO token authentication, Duo
IEEE 802.3ad (LACP)
IP Telephony
VoIP Protocols
H.323, SIP
Expansion Slots
1 (total) / 1 (free) x expansion slot
6 x 1000Base-T - RJ-45 , 2 x 1000Base-T - SFP (mini-GBIC) , 2 x USB , 1 x serial
Rack mount kit
MTBF
51,644 hours
ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, IPv6 Ready
AC 120/230 V
75 Watt
Software Included
WatchGuard Dimension
Shipping Width
55.9 cm
Shipping Depth
53.3 cm
Shipping Height
12.7 cm
Shipping Weight
8.17 kg
5 - 90% (non-condensing)
