WatchGuard Technologies Firebox M400 with 1-yr Total Security Suite
Quicklinx: D320WS00 Mfr#: WGM40641
Firebox M400 firewall is specifically engineered for mid-sized and distributed enterprises that are struggling to effectively and affordably secure networks in the face of explosive growth in bandwidth rates, encrypted traffic, video use and connection speeds. The M400 can run all of their security scanning engines in parallel, ensuring network pros never have to compromise network security for performance. The Total Security Suite turns your Firebox M400 appliance into a comprehensive unified threat management solution. The suite includes powerful UTM security subscriptions that boost defenses in critical attack areas for maximum network protection. An exceptional value, each suite includes subscriptions to Threat Detection and Response, APT Blocker, Data Loss Prevention, Application Control, spamBlocker, Reputation Enabled Defense, WebBlocker, Gateway AntiVirus, and Intrusion Prevention Service, plus Gold level support, and Dimension Command.
  • Best-of-breed security
    Application-layer content inspection recognizes & blocks threats that stateful packet firewalls cannot detect. Powerful subscription-based security services boost protection in critical attack areas for multiple layers of defense. By partnering with leading technology providers, WatchGuard is able to integrate best-of-breed security components into one platform for stronger security at big cost savings.
  • Easy to manage
    WatchGuard Dimension, a public and private cloud-ready visibility solution, instantly turns raw data into security intelligence. Interactive, real-time monitoring and reporting - at no additional charge - give an unprecedented view into network security activity so you can take immediate preventive or corrective actions. RapidDeploy enables quick, secure configuration at remote locations without technical staff. Intuitive management console centrally manages all security functions. WAN and VPN failover provide redundancy for increased reliability. Extend best-in-class UTM security to the WLAN by adding WatchGuard's Wireless Access Points. Drag-and-drop Branch Office VPN setup - three clicks and your remote office is connected.
WatchGuard Firebox M400 - security appliance - with 1 year Total Security Suite
Security appliance
Bundled Services
External - 1U
Ports Qty
8
Performance
Firewall throughput: 8 Gbps , VPN throughput: 4.4 Gbps , Antivirus throughput: 2.5 Gbps , IPS throughput: 4 Gbps , Unified Threat Management (UTM) throughput: 1.4 Gbps , Connection rate: 84000 connections per second
Concurrent connections: 3800000 , Virtual interfaces (VLANs): 300 , Authenticated users: unlimited , Branch office VPN tunnels: 100 , Mobile IPSec VPN tunnels: 150 , Mobile SSL VPN tunnels: 150 , Mobile L2TP VPN tunnels: 150 , QoS hardware queues: 8
VoIP Protocols
H.323, SIP
Rack mount kit
AC 120/230 V
43.1 cm x 30.5 cm x 4.4 cm
Security appliance
Bundled Services
Height (Rack Units)
1U
43.1 cm
30.5 cm
4.4 cm
External
Ports Qty
8
Wired
Network / Transport Protocol
TCP/IP, L2TP, PPPoE, SMTP, FTP, DHCP, DNS, POP3, DDNS
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, CLI
Performance
NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, DiffServ support, IPv6 support, High Availability, Intrusion Prevention System (IPS), deep inspection, HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), VPN failover, WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, TCP proxy, reset button, DHCP relay, on/off switches, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, Reputation Enabled Defense, APT Blocker
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
Authentication Method
SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
IEEE 802.3ad (LACP)
IP Telephony
VoIP Protocols
H.323, SIP
6 x 1000Base-T - RJ-45 , 2 x 1000Base-X - SFP (mini-GBIC) , 1 x serial , 2 x USB
Rack mount kit
MTBF
51,644 hours
ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, IPv6 Ready
Internal power supply
AC 120/230 V
75 Watt
Software Included
10 - 85% (non-condensing)
