The Wasp WWS750 2D Wireless industrial barcode scanner is built for the harshest and most demanding applications in warehousing, transportation and logistics, and manufacturing industries. Its omnidirectional reading capability, four dot aiming system that provides quick and accurate scans and the freedom to roam with Bluetooth wireless connectivity that exceeds far from the base, make this 2D USB scanner kit a preferred scanning solution.
As innovative as it is rugged, the Wasp WWS750 delivers the ergonomic and operational features required for scan-intensive industrial applications. It operates in a wide range of temperatures, has a water and particulate sealing rating of IP65 and maintains its reliability even when subjected to repeated drops on concrete.
The Wasp WWS750 possesses advanced features to excel in the most demanding environments: "Liquid lens" that adapts and focus at different distances; this provides a versatile optic that is able to fulfill any scanning need with a single scanner; the user replaceable lithium-ion battery will provide power for long work. The WWS750 is also Bluetooth 3.0 compliant and features 3 Green Light technology and loud beeper for good-read feedback.
 - Wasp WWS750 - barcode scanner
 - Barcode scanner - handheld - Bluetooth 3.0 - decoded
 - Black, yellow
- Minimum Bar Width
 - 4 mil
- Scan Element Type
 - 2D imager
- Sensor Resolution
 - 864 x 544
- Connectivity Technology
 - Wireless
- Wireless Connectivity
 - Bluetooth 3.0
- Battery
 - 1 x Lithium Ion
 - 11 cm x 7.4 cm x 21.2 cm
 - 380 g
 - 2-year warranty
 - Black, yellow
Barcode
- Interface Type
 - Bluetooth 3.0
- Minimum Bar Width
 - 4 mil
- Scan Element Type
 - 2D imager
- Sensor Resolution
 - 864 x 544
- Light Source Wave Length
 - 630-680 nm
- Skew (Degrees)
 - 40
- Pitch (Degrees)
 - 40
- Print Contrast Signal (PCS)
 - 15%
- Decode Capability
 - Aztec code, China Han Xin Code, Data Matrix, MaxiCode, Micro QR code, QR code, Australian Post, China Post, Japanese Post, Kix (Netherlands) Post, PLANET, Portuguese Post, Postnet, Royal Mail, Swedish Post, EAN/JAN, GS1 DataBar Stacked, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Composites, GS1 DataBar Expanded Stacked, MacroPDF417, MicroPDF417, PDF417, UPC-A / E
- TTL Decoding
 - Decoded
 - Wireless
- OK Notification
 - LED indicator, beeper
 - Rugged, triggered, ESD (electrostatic discharge) safe
 - Bluetooth 3.0
 - IP65, FCC Part 15, IEC 62471, WEEE, RoHS, REACH, CDRH Class II
- Power Device
 - Barcode scanner charging stand
- Battery
 - 1 x Lithium Ion
 - 11 cm
 - 7.4 cm
 - 21.2 cm
 - 380 g
 - Limited warranty - 2 years
 - -20 °C
 - 50 °C
 - 0 - 95% (non-condensing)
- Drop Specification
 - 2 m to concrete
