WASP WWS750 2D Wireless Barcode Reader
Quicklinx: DWV2WS00 Mfr#: 633809002861
Type: Barcode scanner
Form Factor: Handheld
£463.48 ex VAT
£556.17 inc VAT
The Wasp WWS750 2D Wireless industrial barcode scanner is built for the harshest and most demanding applications in warehousing, transportation and logistics, and manufacturing industries. Its omnidirectional reading capability, four dot aiming system that provides quick and accurate scans and the freedom to roam with Bluetooth wireless connectivity that exceeds far from the base, make this 2D USB scanner kit a preferred scanning solution.
As innovative as it is rugged, the Wasp WWS750 delivers the ergonomic and operational features required for scan-intensive industrial applications. It operates in a wide range of temperatures, has a water and particulate sealing rating of IP65 and maintains its reliability even when subjected to repeated drops on concrete.
The Wasp WWS750 possesses advanced features to excel in the most demanding environments: "Liquid lens" that adapts and focus at different distances; this provides a versatile optic that is able to fulfill any scanning need with a single scanner; the user replaceable lithium-ion battery will provide power for long work. The WWS750 is also Bluetooth 3.0 compliant and features 3 Green Light technology and loud beeper for good-read feedback.
Wasp WWS750 - barcode scanner
Barcode scanner - handheld - Bluetooth 3.0 - decoded
Black, yellow
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Sensor Resolution
864 x 544
Wireless
Wireless Connectivity
Bluetooth 3.0
1 x Lithium Ion
11 cm x 7.4 cm x 21.2 cm
380 g
Black, yellow
Barcode
Interface Type
Bluetooth 3.0
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Sensor Resolution
864 x 544
Light Source Wave Length
630-680 nm
Skew (Degrees)
40
Pitch (Degrees)
40
Print Contrast Signal (PCS)
15%
Decode Capability
EAN/JAN, QR code, MaxiCode, Aztec code, MicroPDF417, Postnet, PDF417, Data Matrix, PLANET, Australian Post, China Post, Japanese Post, Kix (Netherlands) Post, MacroPDF417, Royal Mail, Micro QR code, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, Swedish Post, GS1 DataBar Composites, GS1 DataBar Stacked, China Han Xin Code, Portuguese Post, UPC-A / E
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
Triggered, ESD (electrostatic discharge) safe, rugged
Bluetooth 3.0
FCC Part 15, RoHS, WEEE, REACH, IP65, CDRH Class II, IEC 62471
Barcode scanner charging stand
1 x Lithium Ion
11 cm
7.4 cm
21.2 cm
380 g
-20 °C
50 °C
0 - 95% (non-condensing)
Drop Specification
2 m to concrete
Brand: WASP
