WASP WWS500 Freedom Scanner
Quicklinx: 7BQXWS00 Mfr#: 633808920425
Type: Barcode scanner
Form Factor: Portable
Max Paper Size: [N/A]
Compatibility: PC
18 in stock
£187.94 ex VAT
£225.52 inc VAT
The Wasp WWS500 wireless barcode scanner is a lightweight, cordless barcode scanning solution. It delivers unmatched freedom, flexibility and functionality in a value-packed cordless barcode scanner.
Eliminate the clutter and tangle of cords. Rapidly scan barcodes. Capture data instantly. The WWS500 is a real time saver. It's ideal when used as a wireless barcode scanner at retail; as a barcode reader for light industrial manufacturing; or as a cordless barcode scanner in warehouse and distribution centers, offices, mail rooms or mobile service environments.
Simply plug the Bluetooth USB adapter into an available USB slot of a PC. Or use the built-in Bluetooth of mobile devices (eg. Smartphones, PDAs) to connect with the WWS500 wireless barcode reader. The Bluetooth wireless connectivity provides a barcode read range of up to 160' away from the PC or mobile device.
An integrated, rechargeable battery provides exceptionally long scan life on a single charge with over 25,000 continuous scans. This cordless barcode scanner unit has an out of range indicator as well as low battery warning. The CCD LR scan engine scans all popular linear (1D) barcodes with a scan range up to 10" away from the barcode.
Wireless functionality eliminates cumbersome cords, creating a more efficient working environment. Whether you use the WWS500 as a cordless inventory scanner, as a retail wireless barcode reader or for any barcode scanning needs, the WWS500 cordless barcode scanner will make your operations quicker and more efficient.
Wasp WWS500 Freedom Cordless Scanner - barcode scanner
Barcode scanner - portable - Bluetooth
Minimum Bar Width
5 mil
Scan Field Width
15 cm
Scan Element Type
CCD
Scan Speed
150 scan / sec
Wireless
Wireless Connectivity
Bluetooth
1 x Lithium Ion
Microsoft Windows 2000, Microsoft Windows Server 2003, Microsoft Windows XP SP2, Microsoft Windows Vista
10.7 cm x 6.1 cm x 16 cm
160 g
1-year warranty
Barcode
Interface Type
Bluetooth
Minimum Bar Width
5 mil
Scan Field Width
15 cm
Scan Element Type
CCD
Scan Speed
150 scan / sec
Max Working Distance
35 cm
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, ISBN, Telepen, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Code 3 of 9, Interleaved 2 of 5, MSI-Plessey, China Post, GS1 DataBar Omnidirectional
Wireless
Bluetooth
1 x USB - Type A
USB Bluetooth adapter
Power adapter - external
Electric Current Required
230 mA (operating), 120 mA (standby)
1 x Lithium Ion
Software
Software Included
Drivers & Utilities
10.7 cm
6.1 cm
16 cm
160 g
Limited warranty - 1 year
Compatibility: PC
Brand: WASP
Price Range Ex VAT: 150 - 300
