WASP WWS250i 2D Pocket Barcode Scanner (Bluetooth)
Quicklinx: GB76WS00 Mfr#: 633809000201
Type: Barcode scanner
Form Factor: Portable
£256.25 ex VAT
£307.50 inc VAT
The Wasp WWS250i is a 2D handheld pocket-size scanner perfect for error-free, on-the-go, wireless scanning. Its durable housing and compact size make the WWS250i the ideal pocket scanner for the mobile workforce. The WWS250i allows you to streamline business processes, maximize efficiency, and eliminate costly data entry errors on nearly any platform.
The pocket-sized form factor makes it ideal for environments where mobility is vital, including retail, office, healthcare, warehouse management and more. Pair the scanner with your mobile device or PC for a quick mobile solution. Built for busy, high-use environments, the WWS250i has an IP55 rating against moisture and dust and its durable housing is able to withstand multiple drops preventing downtime and costly repairs. Haptic feedback, along with the LED and beep tone indicators, inform users of the power status, wireless connectivity, and barcode detection.
Wasp WWS250i Pocket Barcode Scanner - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 EDR
Minimum Bar Width
5 mil
Scan Speed
30 frames / sec
Wireless
Wireless Connectivity
Bluetooth 2.1 EDR
1 x Lithium Ion
Microsoft Windows, Android, Apple iOS
4.25 cm x 10.2 cm x 2.15 cm
70 g
Barcode
Interface Type
Bluetooth 2.1 EDR
Minimum Bar Width
5 mil
Frame Rate
30 frames / sec
Print Contrast Signal (PCS)
45%
Decode Capability
Code 93, Matrix 2 of 5, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, Code 32, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, PDF417, Data Matrix, Codablock F, IATA 2 of 5, UPC-A/EAN-13 with Extended Coupon Code, EAN-UCC Composite, Micro QR code, China Han Xin Code, Codablock A, MSI
Wireless
OK Notification
Beeper, LED indicator
Bluetooth 2.1 EDR
1 x USB cable - 1.5 m
FCC Part 15 B, FCC Part 15 C, EN 60950-1, IP55, EN 300 328, IEC 62471, EN 301489-1
Electric Current Required
45 mA (standby), 330 mA (operating)
1 x Lithium Ion
4.25 cm
10.2 cm
2.15 cm
70 g
-10 °C
0 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Brand: WASP
