WASP WWS150I Cordless Pocket Barcode Scanner
Quicklinx: GB75WS00 Mfr#: 633808951207
Type: Barcode scanner
Form Factor: Portable
£122.29 ex VAT
£146.74 inc VAT
The Wasp WWS150i pocket Bluetooth barcode scanner provides on-the-go convenience without the tangle of cords. Compatible with different devices, the WWS150i allows you to streamline business processes, maximize efficiency, and eliminate costly data entry errors.
  • Efficient
    Get it done quickly and correctly.
  • Wireless
    Allows for easy access to information on-the-go.
  • Accurate
    Reads barcodes with ease and speed.
  • Rapid scanning
    Scan items quickly and, as a result, spend less time keying in data.
  • Flexibility
    Versatility to meet demands for daily applications.
Wasp WWS150i Pocket Barcode Scanner - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 EDR - decoded
Minimum Bar Width
5 mil
Scan Element Type
CCD
Scan Speed
30 frames / sec
Wireless
DC 3.7 V
1 x Lithium Ion
4.2 cm x 10.2 cm x 2.15 cm
70 g
Barcode
Interface Type
Bluetooth 2.1 EDR
Minimum Bar Width
5 mil
Scan Element Type
CCD
Frame Rate
30 frames / sec
Max Working Distance
30.5 cm
Print Contrast Signal (PCS)
45%
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Telepen, Code 32, Code 39 Full ASCII, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, UK-Plessey, EAN-8/13
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
1 x micro-USB
Hand strap
1 x USB charge cable - external - 1.5 m
FCC Part 15 B, FCC Part 15 C, EN 60950-1, IP55, EN 300 328, IEC 62471, EN 301489-1
Voltage
DC 3.7 V
Electric Current Required
330 mA, 45 mA (standby)
1 x Lithium Ion
4.2 cm
10.2 cm
2.15 cm
70 g
Limited warranty - 2 years , Technical support - lifetime
-10 °C
0 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Brand: WASP
