The Wasp WWS110i is a cost effective pocket Bluetooth barcode scanner that provides on-the-go convenience without the tangle of cords. Its precision laser aiming is designed to enable users to quickly capture any 1D barcodes data in either printed or on-screen (LCD) format.
Built for busy, high-use environments, the WWS110i's is able to withstand multiple 5-foot drops to concrete - preventing downtime and costly repairs. LED and beep tone indicators inform you of the power status, wireless connectivity, and barcode detection. This pocket-sized lightweight wireless 1D barcode scanner is a dexterous mini companion for laptops, tablets, smart phones or other mobile devices with iOS, Android and Windows. This pocket-sized lightweight wireless 1D barcode scanner is a dexterous mini companion for laptops, tablets, smartphones or other mobile devices with iOS, Android and Windows.
- Wasp WWS110i Pocket Barcode Scanner - barcode scanner
- Barcode scanner - portable - Bluetooth 2.1 EDR - decoded
- Black
- Minimum Bar Width
- 4 mil
- Scan Field Width
- 14 cm
- Scan Element Type
- Linear imager
- Scan Speed
- 380 scan / sec
- Connectivity Technology
- Wireless
- Wireless Connectivity
- Bluetooth 2.1 EDR
- Power
- DC 3.7 V
- Battery
- 1 x Lithium Ion
- System Requirements
- Microsoft Windows 2000, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 10 (32/64 bits)
- 2.75 cm x 6.84 cm x 16.2 cm
- 27 g
- 2-year warranty
- Black
Barcode
- Interface Type
- Bluetooth 2.1 EDR
- Minimum Bar Width
- 4 mil
- Scan Field Width
- 14 cm
- Scan Element Type
- Linear imager
- Light Source Wave Length
- 650 nm
- Scan Speed
- 380 scan / sec
- Print Contrast Signal (PCS)
- 30%
- Decode Capability
- Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Telepen, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, UK-Plessey
- TTL Decoding
- Decoded
- Wireless
- OK Notification
- Beeper, LED indicator, vibration
- Laser pointer, ESD (electrostatic discharge) safe, drop protection
- Bluetooth 2.1 EDR
- Flash
- 2 MB
- Included Accessories
- 2 hand straps
- Cables Included
- 1 x micro-USB charge cable - external - 1.5 m
- FCC Part 15 B, EMC, FCC Part 15 C, RoHS, IEC 60950-1, EN 60950-1, WEEE, FDA, EN 300 328, IEC 60825-1 Class 1, EN 301 489-1-17, EN 62479, EN 60825-1 Class 1
- Voltage
- DC 3.7 V
- Electric Current Required
- 170 mA (operating), 60 mA (standby)
- Battery
- 1 x Lithium Ion
- OS Required
- 2.75 cm
- 6.84 cm
- 16.2 cm
- 27 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Drop Specification
- 1.5 m to concrete
