WASP WWS110i Cordless Packet Barcode Scanner
Quicklinx: GB74WS00 Mfr#: 633809002403
Type: Barcode scanner
Form Factor: Portable
  • Windows 8 (32/64 bits)
£114.04 ex VAT
£136.84 inc VAT
The Wasp WWS110i is a cost effective pocket Bluetooth barcode scanner that provides on-the-go convenience without the tangle of cords. Its precision laser aiming is designed to enable users to quickly capture any 1D barcodes data in either printed or on-screen (LCD) format.
Built for busy, high-use environments, the WWS110i's is able to withstand multiple 5-foot drops to concrete - preventing downtime and costly repairs. LED and beep tone indicators inform you of the power status, wireless connectivity, and barcode detection. This pocket-sized lightweight wireless 1D barcode scanner is a dexterous mini companion for laptops, tablets, smart phones or other mobile devices with iOS, Android and Windows. This pocket-sized lightweight wireless 1D barcode scanner is a dexterous mini companion for laptops, tablets, smartphones or other mobile devices with iOS, Android and Windows.
Wasp WWS110i Pocket Barcode Scanner - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 EDR - decoded
Minimum Bar Width
4 mil
Scan Field Width
14 cm
Scan Element Type
Linear imager
Scan Speed
380 scan / sec
Wireless
Wireless Connectivity
Bluetooth 2.1 EDR
DC 3.7 V
1 x Lithium Ion
Microsoft Windows 2000, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 10 (32/64 bits)
2.75 cm x 6.84 cm x 16.2 cm
27 g
Barcode
Interface Type
Bluetooth 2.1 EDR
Minimum Bar Width
4 mil
Scan Field Width
14 cm
Scan Element Type
Linear imager
Light Source Wave Length
650 nm
Scan Speed
380 scan / sec
Print Contrast Signal (PCS)
30%
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Telepen, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, UK-Plessey
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator, vibration
Laser pointer, ESD (electrostatic discharge) safe, drop protection
Bluetooth 2.1 EDR
Flash
2 MB
2 hand straps
1 x micro-USB charge cable - external - 1.5 m
FCC Part 15 B, EMC, FCC Part 15 C, RoHS, IEC 60950-1, EN 60950-1, WEEE, FDA, EN 300 328, IEC 60825-1 Class 1, EN 301 489-1-17, EN 62479, EN 60825-1 Class 1
Voltage
DC 3.7 V
Electric Current Required
170 mA (operating), 60 mA (standby)
1 x Lithium Ion
2.75 cm
6.84 cm
16.2 cm
27 g
0 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Brand: WASP
