The Wasp WRS100SBR Ring Barcode Scanner is a hands-free, ring scanner designed for mobile operators who work with devices such as laptops, tablets, and smartphones. Its ergonomic design includes a double strap to allow operators to wear it on their right or left hand for extended periods of use.
- Wasp WRS100 SBR Ring Barcode Scanner - barcode scanner
- Barcode scanner - wearable - Bluetooth 4.1 - decoded
- Black, yellow
- Minimum Bar Width
- 4 mil
- Scan Field Width
- 13 cm
- Scan Element Type
- Linear imager
- Scan Speed
- 400 scan / sec
- Connectivity Technology
- Wireless
- Wireless Connectivity
- Bluetooth 4.1
- Battery
- 1 x lithium polymer
- 2.76 cm x 4.62 cm x 2.68 cm
- 20.5 g
- 2-year warranty
- Black, yellow
Barcode
- Interface Type
- Bluetooth 4.1
- Minimum Bar Width
- 4 mil
- Scan Field Width
- 13 cm
- Scan Element Type
- Linear imager
- Light Source Wave Length
- 650 nm
- Scan Speed
- 400 scan / sec
- Max Working Distance
- 25.5 cm
- Skew (Degrees)
- 40
- Pitch (Degrees)
- 30
- Print Contrast Signal (PCS)
- 30%
- Decode Capability
- Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Telepen, Code 32, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, UK-Plessey, EAN-8/13
- TTL Decoding
- Decoded
- Wireless
- OK Notification
- Beeper, LED indicator
- ESD (electrostatic discharge) safe, white LEDs illumination, Human Interface Device Profile (HID)
- Bluetooth 4.1
- Flash
- 2 MB
- Cables Included
- 1 x micro-USB to USB cable - external - 1.5 m
- FCC Part 15 B, FCC Part 15 C, WEEE, TELEC, FDA, REACH, IP42, RoHS2, EN 300 328, IEC 60825-1 Class 1, EN 301 489-1-17, EN 62479, IEC/EN 60950-1, EN 60825-1 Class 1
- Power Device
- Barcode scanner charging stand
- Battery
- 2.76 cm
- 4.62 cm
- 2.68 cm
- 20.5 g
- Shipping Width
- 22.86 cm
- Shipping Depth
- 15.24 cm
- Shipping Height
- 5.08 cm
- Shipping Weight
- 200 g
- Limited warranty - 2 years
- -10 °C
- 50 °C
- 0 - 95% (non-condensing)
- Drop Specification
- 1.5 m
