WASP WRS100SBR 1D Ring Barcode Scanner
Quicklinx: GB7CWS00 Mfr#: 633809004018
Type: Barcode scanner
Form Factor: Wearable
£125.13 ex VAT
£150.15 inc VAT
The Wasp WRS100SBR 1D ring barcode scanner with built-in Bluetooth 4.1 technology, can send data to the host up to 32 ft. (10 meters) away. This wearable lightweight wireless 1D barcode scanner enables hands-free scanning for mobile operators who work with laptops, tablets, smart phones or other mobile devices with iOS, Android and Windows.
The double strap design allows mobile operators to wear on either their right or left hand for long periods of time, and provide the user freedom of movement to perform barcode scanning tasks comfortably while keeping both hands free. The dual touch activated buttons can reduce working interference and increase operators' satisfaction.
The Wasp WRS100SBR 1D ring barcode scanner is designed to enable users to quickly capture any 1D barcode data in either printed or on-screen (LCD) format. Built with Bluetooth 4.1 and power saving technology, MT500L ring scanner can help user to operate around the clock with less downtime ensuring mobile productivity during the entire busy shift for more than 8 working hours.
Quickly capture any 1D barcode data in either printed or on-screen (LCD) format. Built-in memory of 2MB, ring scanner can store up to 20,000 data scanned in user-friendly file format. Compact form factor withstands multiple 5' drops to concrete. Wireless connectivity allows for up to 33' line of sight from a mobile device. Compatible with Android and iOS devices, including iPhone, or iPad.
Wasp WRS100 SBR Ring Barcode Scanner - barcode scanner
Barcode scanner - wearable - Bluetooth 4.1 - decoded
Black, yellow
Minimum Bar Width
4 mil
Scan Field Width
13 cm
Scan Element Type
Linear imager
Scan Speed
400 scan / sec
Wireless
Wireless Connectivity
Bluetooth 4.1
1 x lithium polymer
2.76 cm x 4.62 cm x 2.68 cm
20.5 g
Black, yellow
Barcode
Interface Type
Bluetooth 4.1
Minimum Bar Width
4 mil
Scan Field Width
13 cm
Scan Element Type
Linear imager
Light Source Wave Length
650 nm
Scan Speed
400 scan / sec
Max Working Distance
25.5 cm
Skew (Degrees)
40
Pitch (Degrees)
30
Print Contrast Signal (PCS)
30%
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Telepen, Code 32, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, UK-Plessey, EAN-8/13
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
ESD (electrostatic discharge) safe, white LEDs illumination, Human Interface Device Profile (HID)
Bluetooth 4.1
Flash
2 MB
1 x micro-USB to USB cable - external - 1.5 m
FCC Part 15 B, FCC Part 15 C, WEEE, TELEC, FDA, REACH, IP42, RoHS2, EN 300 328, IEC 60825-1 Class 1, EN 301 489-1-17, EN 62479, IEC/EN 60950-1, EN 60825-1 Class 1
1 x lithium polymer
2.76 cm
4.62 cm
2.68 cm
20.5 g
Shipping Width
22.86 cm
Shipping Depth
15.24 cm
Shipping Height
5.08 cm
Shipping Weight
200 g
-10 °C
50 °C
0 - 95% (non-condensing)
Drop Specification
1.5 m
Brand: WASP
