The Wasp WPS1500 Omni-Directional Barcode Scanner is a high-performance scanner ideal for retail point-of-sale (POS) and warehouse applications. Utilizing a digital imaging scan engine, the WPS1500 is capable of reading both 1D and 2D barcodes with ease. Unique technology optimizes light levels and provides the ability to read barcodes from mobile phones, tablets, and computer displays.
For busy retail environments, the WPS1500 can be used in hands-free and handheld mode. Checkout personnel by simply waving the barcode label or tag across the face of the scanner. Regardless of barcode label orientation, the WPS1500 Omni-Directional scan engine will quickly read the barcode and assist in the rapid check out of your customers.
The WPS1500 omni-directional barcode scanner can also be used to scan invoices or pick lists and is a perfect addition to any warehouse. Its rugged housing can withstand repeated 4 ft. drops to concrete, and is sealed against moisture and dust (IP52 rated).
For noisy environments, the WPS1500 provides Green Spot visual feedback, perfect for confirming a positive scan or for precise targeting of a single barcode from a group of barcodes.
- Wasp WPS1500 - barcode scanner
- Barcode scanner - desktop - stationary - USB - decoded
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Minimum Bar Width
- 5 mil
- Scan Element Type
- 2D imager
- Sensor Resolution
- 1280 x 800
- Connectivity Technology
- Wired
- 6 cm x 7.5 cm x 13.8 cm
- 240 g
- 1-year warranty
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 5 mil
- Scan Element Type
- 2D imager
- Sensor Resolution
- 1280 x 800
- Skew (Degrees)
- 75
- Pitch (Degrees)
- 65
- Print Contrast Signal (PCS)
- 25%
- Decode Capability
- Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, MicroPDF417, UPC, Postnet, PDF417, Data Matrix, PLANET, Australian Post, British Post, Canadian Post, China Post, Japanese Post, Kix (Netherlands) Post, Royal Mail, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, Swedish Post, GS1 DataBar Composites, GS1 DataBar Stacked, Portuguese Post
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- 16 kV ESD protection (air discharge)
- 1 x USB
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - external
- IP52
- Electric Current Required
- 300 mA (standby), 500 mA (operating)
- 6 cm
- 7.5 cm
- 13.8 cm
- 240 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Drop Specification
- 1.2 m
