The WPL618 industrial barcode printer is both versatile and easy to use with features like direct thermal and thermal transfer printing, 6-button color LCD resistive touch screen for fast configuration, and enhanced print quality.
- Wasp WPL618 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 18 kg
- Max Media Size
- Roll (11.4 cm)
- Max Media Size (Custom)
- 115 mm
- Print Speed
- Up to 457 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB 2.0, LAN, serial, USB host
- RAM Installed (Max)
- 512 MB SDRAM
- Flash Memory Installed (Max)
- 512 MB
- Language Simulation
- ZPL, ZPL II, EPL, WPL
- Barcodes
- Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, China Post, Plessey, Code 128B, Code 128C, Code 128A, EAN-128, EAN-8, EAN-13, MSI, RSS
- Media Type
- Labels, continuous forms, fanfold paper, die cut labels
- Black Mark sensor, gap sensor, ribbon end sensor, ribbon encode sensor, open head sensor
- Total Media Capacity
- 1 roll
- 2-year warranty
- 30 cm x 51 cm x 39.3 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
Printer
- Print Speed
- Up to 457 mm/sec - 203 dpi
- Built-in Devices
- 4.3 inch LCD touch screen
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- Barcodes
RAM
- 512 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 512 MB
Media Handling
- Media Type
- Max Media Size
- Roll (11.4 cm)
- 115 mm
- Media Sizes
- Roll (11.4 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 25400 mm
- Media Thickness Range
- 0.076 mm - 0.305 mm
- Roll Core Diameter
- 76.2 mm
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (11.4 cm)
- Connections
- 1 x USB 2.0 , 1 x RS-232 , USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- Cables Included
- 1 x USB cable
- FCC Class B certified, UL, TUV, cUL, CB, C-Tick Class B, CCC, RoHS, WEEE, EAC, BIS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 25 - 85% (non-condensing)
- 30 cm
- 51 cm
- 39.3 cm
- 18 kg
